Datasheet Texas Instruments 7700401EA — Даташит
| Серия | SN54S139 |
| Модель | 7700401EA |
Двойные 2-4-строчные декодеры/демультиплексоры 16-CDIP от -55 до 125
Dual 2-Line To 4-Line Decoders/Demultiplexer datasheet
PDF, 1.1 Мб, Версия: A, Файл опубликован: 30 сен 2009
Купить 7700401EA на РадиоЛоцман.Цены — от 1 236 до 5 196 ₽10 предложений от 10 поставщиков Микросхема Логический контроллер, Decoder/Demultiplexer Dual 2-to-4 16Pin CDIP Tube | |||
| 7700401EA Texas Instruments | 1 825 ₽ | ||
| 7700401EA Rochester Electronics | 1 997 ₽ | ||
| 7700401EA Texas Instruments | по запросу | ||
| 7700401EA Molex | по запросу | ||
| Pin | 16 | 16 |
| Package Type | J | J |
| Industry STD Term | CDIP | CDIP |
| JEDEC Code | R-GDIP-T | R-GDIP-T |
| Package QTY | 1 | 1 |
| Carrier | TUBE | TUBE |
| Маркировка | SNJ54S139J | 7700401EA |
| Width (мм) | 6.92 | 6.92 |
| Length (мм) | 19.56 | 19.56 |
| Thickness (мм) | 4.57 | 4.57 |
| Pitch (мм) | 2.54 | 2.54 |
| Max Height (мм) | 5.08 | 5.08 |
| RoHS | See ti.com |
- Live InsertionPDF, 150 Кб, Файл опубликован: 1 окт 1996
Many applications require the ability to exchange modules in electronic systems without removing the supply voltage from the module (live insertion). For example an electronic telephone exchange must always remain operational even during module maintenance and repair. To avoid damaging components additional circuitry modifications are necessary. This document describes in detail the phenomena tha - Input and Output Characteristics of Digital Integrated CircuitsPDF, 1.7 Мб, Файл опубликован: 1 окт 1996
This report contains a comprehensive collection of the input and output characteristic curves of typical integrated circuits from various logic families. These curves go beyond the information given in data sheets by providing additional details regarding the characteristics of the components. This knowledge is particularly useful when for example a decision must be made as to which circuit shou - Designing With Logic (Rev. C)PDF, 186 Кб, Версия: C, Файл опубликован: 1 июн 1997
Серия: SN54S139 (5)
- 7700401EA 7700401FA SN54S139J SNJ54S139J SNJ54S139W
- Semiconductors > Space & High Reliability > Logic Products > Specialty Logic Products > Decoders/Encoders/Multiplexers
