Datasheet Texas Instruments LM95213CISDX/NOPB — Даташит
| Серия | LM95213 |
| Модель | LM95213CISDX/NOPB |
В±2В°C Dual Remote and Local Temperature Sensor with SMBus Interface 14-WSON -40 to 140
2-Diode Input & Local Digital Temp Sensor w/ Two-Wire Interface & TCRIT Outputs datasheet
PDF, 1.1 Мб, Версия: A, Файл опубликован: 22 мар 2013
Купить LM95213CISDX/NOPB на РадиоЛоцман.Цены — от 80 до 90 ₽9 предложений от 9 поставщиков SENSOR DIGITAL -40C-125C 14WSON. Temperature Sensor Digital, Local/Remote -40°C ~ 125°C 10 b 14-WSON (4x4). Temperature Sensors - Analog and Digital... | |||
| LM95213CISDX/NOPB Texas Instruments | 90 ₽ | ||
| LM95213CISDX/NOPB Texas Instruments | по запросу | ||
| Pin | 14 |
| Package Type | NHL |
| Industry STD Term | WSON |
| JEDEC Code | S-PDSO-N |
| Package QTY | 4500 |
| Carrier | LARGE T&R |
| Маркировка | 95213CI |
| Width (мм) | 4 |
| Length (мм) | 4 |
| Thickness (мм) | .8 |
| Pitch (мм) | .5 |
| Max Height (мм) | .8 |
| Mechanical Data | Скачать |
| Interface | I2C,SMBus |
| Local Sensor Accuracy(Max) | 2 +/- C |
| Рабочий диапазон температур | от -40 до 140 C |
| Package Group | WSON |
| Package Size: mm2:W x L | See datasheet (WSON) PKG |
| Rating | Catalog |
| Remote Channel | 2 |
| Remote Diode Temp Range for Listed Accuracy | 60 to 100 C |
| Remote Sensor Accuracy(Max) | 1.1 +/- C |
| Remote Sensor Correction | Offset Correction Register |
| Remote Temp Resolution(Max) | 13 bits |
| Special Features | One shot conversion control,Programmable Alert,Programmable conversion rate,Remote diode fault detection,Shutdown,Thermal diode input stage filtering |
| Supply Current(Typ) | 570 uA |
| Supply Voltage(Max) | 3.6 В |
| Supply Voltage(Min) | 3 В |
| Temp Resolution(Max) | 11 bits |
- Evaluation Modules & Boards: LM95213EB
2-Diode Input and Local Digital Temperature Sensor with Two-Wire Interface and Outputs EVM
Серия: LM95213 (2)
- LM95213CISD/NOPB LM95213CISDX/NOPB
- Semiconductors > Sensing Products > Temperature Sensors > Remote / Multi-channel Temperature Sensors
