Datasheet Texas Instruments LM5021MM-1/NOPB — Даташит
СерияLM5021
МодельLM5021MM-1/NOPB
ШИМ-контроллер в режиме переменного и постоянного тока 8-VSSOP от -40 до 125
LM5021 AC-DC Current-Mode PWM Controller datasheet
PDF, 5.1 Мб, Версия: E, Файл опубликован: 24 дек 2014
Package TypeDGK
Industry STD TermVSSOP
Package QTY1000
Маркировка21-1
Width (мм)3
Length (мм)3
Thickness (мм).97
Max Height (мм)1.07
Control MethodCurrent
Duty Cycle(Max)80 %
Frequency(Max)1000 kHz
Frequency(Min)10 kHz
Package GroupVSSOP
Package Size: mm2:W x L8VSSOP: 15 mm2: 4.9 x 3(VSSOP) PKG
Special FeaturesSSR,DCM,CCM,Frequency Synchronization,Smart Meters Compatible,Audio Compatible,Motor Drive Compatible,Power Delivery Compatible
UVLO Thresholds On/Off20/7.25 В
  • AN-2102 LM3464 and LM5021 DHC 25W Reference Designs (Rev. A)
    PDF, 8.3 Мб, Версия: A, Файл опубликован: 1 май 2013
    This evaluation board consists of a Texas Instruments LM5021-based 120Vac 24W AC/DC flybackconverter and a LM3464-based dynamic head room control (DHC) four channel LED driver IC. Thisdemonstration platform was developed so that the customers could evaluate the LM3464 with an AC/DCsupply.
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > Flyback Controller
LM5021MM1/NOPB, LM5021MM 1/NOPB
На английском языке: Datasheet Texas Instruments LM5021MM-1/NOPB
