Datasheet Texas Instruments TPS54260QDGQRQ1 — Даташит
СерияTPS54260-Q1
МодельTPS54260QDGQRQ1
Автомобильный понижающий преобразователь 3,5–60 В, 2,5 А с Eco-Mode™ 10-MSOP-PowerPAD от -40 до 125
TPS54260-Q1 3.5-V to 60-V Step-Down Converter With Eco-modeв„ў datasheet
PDF, 2.1 Мб, Версия: F, Файл опубликован: 14 авг 2015
Pin10
Package TypeDGQ
Industry STD TermHVSSOP
JEDEC CodeS-PDSO-G
Package QTY2500
Маркировка5426Q
Width (мм)3
Length (мм)3
Thickness (мм)1.02
Pitch (мм).5
Max Height (мм)1.1
Control ModeCurrent Mode
Duty Cycle(Max)100 %
Iout(Max)2.5 A
Iq(Typ)0.138 мА
Package GroupMSOP-PowerPAD
RatingAutomotive
Regulated Outputs1
Special FeaturesEnable,Frequency Synchronization,Light Load Efficiency,Power Good,Tracking,UVLO Adjustable
Switching Frequency(Max)2500 kHz
Switching Frequency(Min)100 kHz
ТипConverter
Vin(Max)60 В
Vin(Min)3.5 В
Vout(Max)58 В
Vout(Min)0.8 В
  • Evaluation Modules & Boards: TPS54260EVM-597
    2.5A, 10.8 to 13.2 Vin, SWIFTВ™ Converter Evaluation Module
  • Passing CISPR25 Radiated Emissions Using the TPS54160-Q1
    PDF, 857 Кб, Файл опубликован: 4 дек 2013
    This application report provides a summary of CISPR25-Radiated Emissions test results using the TPS54160-Q1 high-frequency buck converter. Similar results can be achieved using other devices in this family. This family of buck converters is capable of passing CISPR25 and other automotive electromagnetic-compatibility (EMC) test specifications. The TPS54160 family of devices does not require the us
  • TPS54xx0-Q1 and TPS57xx0-Q1 Pin Open and Short Test Results (Rev. B)
    PDF, 39 Кб, Версия: B, Файл опубликован: 3 ноя 2015
    This application note provides Pin Open and Short Test Results for the device pins of the TPS54xx0-Q1and TPS57xx0-Q1 family of step-down SWIFTв„ў DC-DC converters. The TPS54xx0-Q1 and TPS57xx0-Q1 family of power devices consists of high-input-voltage step-down regulators that provide a variety ofcurrent options.
  • Interfacing TPS57xxx-Q1 and TPS65320-Q1 Family Devices With Low Impendence Exter
    PDF, 624 Кб, Файл опубликован: 8 дек 2015
  • Design Considerations for DC-DC Converters in Fast-Input Slew Rate Applications
    PDF, 191 Кб, Файл опубликован: 5 мар 2015
    This application report describes the ways to optimize the design of DC-DC converters (TPS54040-Q1, TPS54060-Q1, TPS54140-Q1, TPS54160-Q1, TPS54240-Q1, TPS54260-Q1, TPS57040-Q1, TPS57060-Q1, TPS57140-Q1, and TPS57160-Q1) in applications with fast transition at the input voltage on the rising and falling edges. First, the issues faced under such a scenario are analyzed. Then, design considerations
Серия: TPS54260-Q1 (3)
На английском языке: Datasheet Texas Instruments TPS54260QDGQRQ1
