Datasheet Texas Instruments LM2597HVM-5.0 — Даташит
СерияLM2597HV
МодельLM2597HVM-5.0
SIMPLE SWITCHER Преобразователь мощности, 150 кГц, 0,5 А, понижающий стабилизатор напряжения, с функциями 8-SOIC от -40 до 125
LM2597, LM2597HV SIMPLE SWITCHERВ® Power Converter 150-kHz 0.5-A Step-Down Voltage Regulator With Features datasheet
PDF, 2.8 Мб, Версия: D, Файл опубликован: 31 май 2016
Pin88
Package TypeDD
Industry STD TermSOICSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
CarrierTUBETUBE
МаркировкаM-5.02597H
Width (мм)3.913.91
Length (мм)4.94.9
Thickness (мм)1.581.58
Pitch (мм)1.271.27
Max Height (мм)1.751.75
Control ModeVoltage Mode
Duty Cycle(Max)100 %
Iout(Max)0.5 A
Iq(Typ)5 мА
Regulated Outputs1
Special FeaturesPower Good
Switching Frequency(Max)173 kHz
Switching Frequency(Min)110 kHz
ТипConverter
Vin(Max)60 В
Vin(Min)4.5 В
Vout(Max)37 В
Vout(Min)3.3 В
RoHSНе совместим
  • Cost-Effective Transformerless Offline Supply for Light Load Applications (Rev. A)
    PDF, 295 Кб, Версия: A, Файл опубликован: 16 июн 2015
    This design idea provides a simple non-isolated AC/DC power supply for low power applications. Thedesign uses a "capacitive-dropper" front-end combined with a LM46000 SIMPLE SWITCHERВ® buckregulator from Texas Instruments. The circuit provides 3.3 V at a minimum of 100 mA from a line supply of90 VAC to 265 VAC. Theory of operation as well as design equations and performance results are given.
  • Cap Drop Offline Supply for E-Meters
    PDF, 291 Кб, Файл опубликован: 16 июн 2015
    This design idea provides a simple non-isolated AC/DC power supply for low power applications such assmart grid E-meter applications. The design uses a "capacitive-dropper" front-end combined with aLM46000 SIMPLE SWITCHERВ® buck regulator from Texas Instruments. The circuit provides 3.3 V at aminimum of 50 mA from a line supply of 90 VAC to 265 VAC. Theory of operation as well as designequa
  • Low EMI Layout Made SIMPLE With LM43600/1/2/3 and LM46000/1/2 (Rev. A)
    PDF, 512 Кб, Версия: A, Файл опубликован: 12 сен 2014
    Printed Circuit Board (PCB) layout for Switched Mode Power Supplies (SMPS) is critical to achieve proper converter operation good thermal performance and excellent radiated EMI performance. Optimized board layout for low radiated EMI is made very simple by the package and pin arrangement of the SIMPLE SWITCHER Synchronous Buck Converter family LM4360x and LM4600x
  • Simple Techniques Minimize Cross-Coupling in Distributed Power Systems
    PDF, 335 Кб, Файл опубликован: 21 мар 2007
  • AN-1081 Low-Cost Low-Parts-Count DC/DC Converter With Multiple Outputs (Rev. B)
    PDF, 124 Кб, Версия: B, Файл опубликован: 23 апр 2013
    This application report describes a simple low cost, low parts-count multiple output DC/DC converterbased on the LM2596 five terminal step-down switching regulator. The circuit described provides multipleoutput voltages (positive and negative) with good regulation using a step-down converter circuit withflyback windings. It uses only one switching regulator IC.
LM2597HVM5.0, LM2597HVM 5.0
На английском языке: Datasheet Texas Instruments LM2597HVM-5.0
