Datasheet Texas Instruments BQ24707RGRR — Даташит
СерияBQ24707
МодельBQ24707RGRR
Высокочастотный высокопроизводительный контроллер заряда SMBus 20-VQFN от -40 до 85
bq24707x 1-4 Cell Li+ Battery SMBus Charge Controller With Independent Comparator and Advanced Circuit Protection datasheet
PDF, 1.6 Мб, Версия: C, Файл опубликован: 31 июл 2015
Pin20
Package TypeRGR
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY3000
МаркировкаBQ707
Width (мм)3.5
Length (мм)3.5
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
Absolute Vin (safety rating)(Max)(30 В
Battery Charge Voltage(Max)19.2 В
Battery Charge Voltage(Min)1.024 В
Cell ChemistryLi-Ion/Li-Polymer
Charge Current(Max)8 A
Control InterfaceSMBus
Control TopologySwitch-Mode Buck
Number of Series Cells1,2,3,4
Operating Vin(Max)24 В
Operating Vin(Min)4.5 В
Package GroupVQFN
Package Size: mm2:W x L20VQFN: 12 mm2: 3.5 x 3.5(VQFN) PKG
Special FeaturesPower Path
USB FeatureN/A
  • Evaluation Modules & Boards: BQ24707EVM-558
    Evaluation Module for BQ24707 High-Frequency, High Performance SMBus Charge Controller
  • How to Operate bq20z7x/8x/9x Fuel Gauge and bq24707/25/26 Chrgr w/o Host Cntrlr
    PDF, 153 Кб, Файл опубликован: 31 авг 2011
    The bq24707/26/25 chargers and the bq20z7x/8x/9x gas gauges are both SBS-compliant integrated circuits. In this application report, both of these chargers and gas gauges are used together as a nonhost-control, battery charging system. An external regulator, TPS7A49xx, is added to the system to prevent shutting down the system during a deeply discharged state of the battery cells. It provides awa
  • bq24707/25/26 Input Voltage DPM
    PDF, 97 Кб, Файл опубликован: 26 янв 2011
    The bq24707/25/26 are high-efficiency synchronous battery chargers. They offer low component count for space-constrained, multichemistry, battery-charging applications. They feature real-time system control onthe ILIM pin to limit the charge current. In this application report, the ILIM pin is used to implement real-time, input-voltage, dynamic power management. It is used to reduce the charging
  • How to Review a Multicell Switching Charger Schematic
    PDF, 196 Кб, Файл опубликован: 21 сен 2011
    This application report provides a checklist for reviewing a switching charger schematic and explains each item in the list.
Серия: BQ24707 (2)
  • Semiconductors > Power Management > Battery Management Products > Battery Charger IC
На английском языке: Datasheet Texas Instruments BQ24707RGRR
