Datasheet Texas Instruments TPS61169DCKR — Даташит
СерияTPS61169
МодельTPS61169DCKR
TPS61169 Сильноточный повышающий драйвер WLED, 38 В 5-SC70 -40–85
TPS61169 38-V High Current-Boost WLED Driver With PWM Control datasheet
PDF, 1.1 Мб, Версия: A, Файл опубликован: 18 мар 2016
Pin5
Package TypeDCK
Industry STD TermSOT-SC70
Package QTY3000
МаркировкаSZL
Width (мм)1.25
Length (мм)2
Thickness (мм).9
Max Height (мм)1.1
Количество каналов1
Duty Cycle(Max)100 %
LED27
LED Current Per Channel400 мА
Package GroupSC70
Package Size: mm2:W x L5SC70: 4 mm2: 2.1 x 2(SC70) PKG
Peak Efficiency90 %
Shutdown Current(Typ)1 uA
Special FeaturesOVP,PWM Control
Switching Frequency(Max)1500 kHz
TopologyBoost
ТипInductive
Vin(Max)5.5 В
Vin(Min)2.7 В
Vout(Max)38 В
Vout(Min)2.7 В
  • Evaluation Modules & Boards: TPS61169EVM
    TPS61169EVM WLED Driver Evaluation Board
  • Simple Backlight Driver Dimming Performance
    PDF, 74 Кб, Файл опубликован: 20 мар 2017
    The TPS61158, TPS61160/61, TPS61162/63A, TPS61165, and TPS61169 (hereafter TPS611xx) are simple backlight drivers commonly used in smartphones and tablets. These devices support PWM dimming with an input voltage as low as 2.7 V. This application note discusses the requirements for using tje TPS611xx parts at the lowest performance specifications for PWM dimming.
  • Analog PWM Dimming in White-LED Drivers
    PDF, 539 Кб, Файл опубликован: 21 дек 2016
    Pulse-width modulation (PWM) is a common type of dimming used to adjust the current in white-LEDdriver devices. PWM dimming takes a rectangle waveform with variable positive duty cycle (D) and adjuststhe LED current proportionally. For many smaller format white LED drivers (7-inch screen size or smaller),the PWM signal is converted to a DC control voltage and made to drive the LED current in
  • Schottky Diode Selection in Asynchronous Boost Converters
    PDF, 491 Кб, Файл опубликован: 6 сен 2016
    Asynchronous boost converters require a Schottky diode as the rectifying element due to the diode's lowforward voltage and fast turn-on time. Because of these characteristics asynchronous boost converterscan have as good as, or better efficiency, than synchronous boost converters. This is especially true whenthe boost conversion ratios (VOUT/VIN) are high, and the Schottky diode conduction t
  • Inductor Selection in Boost Converters for LCD Backlight Applications
    PDF, 764 Кб, Файл опубликован: 24 окт 2016
    White LED drivers for LCD back-light applications are often designed for battery-powered devices. This makes circuit size and efficiency crucial. Because of this, selecting the optimal inductor is one of the mostimportant aspects of the design. This application note discusses the important parameters of the inductorand how to select the right inductor for the application.
Серия: TPS61169 (1)
  • TPS61169DCKR
  • Semiconductors > Power Management > LED Driver > Backlight LED Driver
На английском языке: Datasheet Texas Instruments TPS61169DCKR
