Линейка продуктов KEEN SIDE
Datasheet Texas Instruments THS4509RGTRG4 — Даташит
СерияTHS4509
МодельTHS4509RGTRG4
Широкополосный операционный усилитель 16-VQFN от -40 до 85
THS4509 Wideband, Low-Noise, Low-Distortion, Fully-Differential Amplifier datasheet
PDF, 2.2 Мб, Версия: I, Файл опубликован: 29 июл 2016
Pin16
Package TypeRGT
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY3000
Маркировка4509
Width (мм)3
Length (мм)3
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
2nd Harmonic104 dBc
3rd Harmonic108 dBc
@ MHz10
Acl, min spec gain2 V/V
Additional FeaturesShutdown
АрхитектураFully Differential
BW @ Acl2000 МГц
CMRR(Typ)90 дБ
GBW(Typ)3000 МГц
Input Bias Current(Max)15500000 pA
Iq per channel(Max)40.9 мА
Iq per channel(Typ)37.7 мА
Количество каналов1
Offset Drift(Typ)2.6 uV/C
Output Current(Typ)96 мА
Package GroupVQFN
Package Size: mm2:W x L16VQFN: 9 mm2: 3 x 3(VQFN) PKG
Rail-to-RailNo
Slew Rate(Typ)6600 V/us
Total Supply Voltage(Max)5.25 +5V=5, +/-5V=10
Total Supply Voltage(Min)3 +5V=5, +/-5V=10
Vn at 1kHz(Typ)10 нВ/rtГц
Vn at Flatband(Typ)1.9 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)4 мВ
  • Evaluation Modules & Boards: ADS6122EVM
    ADS6122 12-Bit, 65-MSPS Analog-to-Digital Converter Evaluation Module
  • Evaluation Modules & Boards: ADS6124EVM
    ADS6124 12-Bit, 105-MSPS Analog-to-Digital Converter Evaluation Module
  • Evaluation Modules & Boards: ADS6143EVM
    ADS6143 14-Bit, 80-MSPS Analog-to-Digital Converter Evaluation Module
  • Evaluation Modules & Boards: THS4509EVM
    THS4509EVM Evaluation Module
  • Evaluation Modules & Boards: ADS54RF63EVM
    ADS54RF63 12-Bit, 550-MSPS, RF Sampling Analog-to-Digital Converter Evaluation Module
  • Evaluation Modules & Boards: ADS6123EVM
    ADS6123 12-Bit, 80-MSPS Analog-to-Digital Converter Evaluation Module
  • Evaluation Modules & Boards: ADS6445EVM
    ADS6445 Quad-Channel, 14-Bit, 125-MSPS Analog-to-Digital Converter Evaluation Module
  • Evaluation Modules & Boards: ADS6425EVM
    ADS6425 Quad-Channel, 12-Bit, 125-MSPS Analog-to-Digital Converter Evaluation Module
  • Evaluation Modules & Boards: ADS6225EVM
    ADS6225 Dual-Channel, 12-Bit, 125-MSPS Analog-to-Digital Converter Evaluation Module
  • Evaluation Modules & Boards: ADS6224EVM
    ADS6224 Dual-Channel, 12-Bit, 105-MSPS Analog-to-Digital Converter Evaluation Module
  • Evaluation Modules & Boards: ADS6442EVM
    ADS6442 Quad-Channel, 14-Bit, 65-MSPS Analog-to-Digital Converter Evaluation Module
  • Evaluation Modules & Boards: ADS6422EVM
    ADS6422 Quad-Channel, 12-Bit, 65-MSPS Analog-to-Digital Converter Evaluation Module
  • Evaluation Modules & Boards: ADS6222EVM
    ADS6222 Dual-Channel, 12-Bit, 65-MSPS Analog-to-Digital Converter Evaluation Module
  • Evaluation Modules & Boards: ADS6242EVM
    ADS6242 Dual-Channel, 14-Bit, 65-MSPS Analog-to-Digital Converter Evaluation Module
  • Evaluation Modules & Boards: ADS6223EVM
    ADS6223 Dual-Channel, 12-Bit, 80-MSPS Analog-to-Digital Converter Evaluation Module
  • Evaluation Modules & Boards: ADS6423EVM
    ADS6423 Quad-Channel, 12-Bit, 80-MSPS Analog-to-Digital Converter Evaluation Module
  • Evaluation Modules & Boards: ADS6443EVM
    ADS6443 Quad-Channel, 14-Bit, 80-MSPS Analog-to-Digital Converter Evaluation Module
  • Evaluation Modules & Boards: ADS6243EVM
    ADS6243 Dual-Channel, 14-Bit, 80-MSPS Analog-to-Digital Converter Evaluation Module
  • Evaluation Modules & Boards: ADS6144EVM
    ADS6144 14-Bit, 105-MSPS Analog-to-Digital Converter Evaluation Module
  • Evaluation Modules & Boards: ADS6142EVM
    ADS6142 14-Bit, 65-MSPS Analog-to-Digital Converter Evaluation Module
  • Evaluation Modules & Boards: ADS62C17EVM
    ADS62C17 Dual-Channel, 11-Bit, 200-MSPS Analog-to-Digital Converter Evaluation Module
  • Evaluation Modules & Boards: THS4508EVM
    THS4508EVM Evaluation Module
  • Evaluation Modules & Boards: THS4520EVM
    THS4520EVM Evaluation Module
  • Evaluation Modules & Boards: THS4511EVM
    THS4511EVM Evaluation Module
  • Evaluation Modules & Boards: THS4513EVM
    THS4513EVM Evaluation Module
  • Evaluation Modules & Boards: ADS5474EVM
    ADS5474 14-Bit, 400-MSPS Analog-to-Digital Converter Evaluation Module
  • Evaluation Modules & Boards: ADS6125EVM
    ADS6125 12-Bit, 125-MSPS Analog-to-Digital Converter Evaluation Module
  • Output impedance matching with fully differential operational amplifiers
    PDF, 747 Кб, Файл опубликован: 11 мар 2009
  • Low-power, high-intercept interface to the ADS5424, 105-MSPS converter
    PDF, 478 Кб, Файл опубликован: 10 окт 2005
  • Fully differential amplifiers applications:Line termination,driving high-speed..
    PDF, 255 Кб, Файл опубликован: 2 мар 2005
  • Using fully differential op amps as attenuators, Part 3
    PDF, 568 Кб, Файл опубликован: 4 окт 2009
  • Using fully differential op amps as attenuators, Part 2
    PDF, 531 Кб, Файл опубликован: 14 июл 2009
  • Design for a Wideband Differential Transimpedance DAC Output (Rev. A)
    PDF, 438 Кб, Версия: A, Файл опубликован: 17 окт 2016
    High-speed digital-to-analog converters commonly offer a complementary current output signal. Most output interface implementations use either a resistive load and/or a transformer to convert this current source signal to a voltage. Where a dc-coupled interface is required, a carefully designed differential transimpedance stage can offer an attractive alternative. Design considerations and options
  • Analysis of fully differential amplifiers
    PDF, 295 Кб, Файл опубликован: 11 мар 2005
  • Q3 2009 Issue Analog Applications Journal
    PDF, 2.1 Мб, Файл опубликован: 14 июл 2009
  • Fully-Differential Amplifiers (Rev. E)
    PDF, 867 Кб, Версия: E, Файл опубликован: 19 сен 2016
    Differential signaling has been commonly used in audio, data transmission, and telephone systems for many years because of its inherent resistance to external noise sources. Today, differential signaling is becoming popular in high-speed data acquisition, where the ADC’s inputs are differential and a differential amplifier is needed to properly drive them.Two other advantages of di
  • Q1 2009 Issue Analog Applications Journal
    PDF, 1.4 Мб, Файл опубликован: 11 мар 2009
  • Q4 2009 Issue Analog Applications Journal
    PDF, 1.5 Мб, Файл опубликован: 4 окт 2009
  • Driving High-Speed ADCs: Circuit Topologies and System-Level Parameters (Rev. A)
    PDF, 327 Кб, Версия: A, Файл опубликован: 10 сен 2010
    This application report discusses the performance-related aspects of passive and active interfaces at the analog input of high-speed pipeline analog-to-digital converters (ADCs). The report simplifies the many possibilities into two main categories: passive and active interface circuits. The first section of the report gives an overview of equivalent models of buffered and unbuffered ADC input cir
Серия: THS4509 (4)
На английском языке: Datasheet Texas Instruments THS4509RGTRG4
