Datasheet Texas Instruments SN74AS240ADW — Даташит
СерияSN74AS240A
МодельSN74AS240ADW
Восьмеричные буферы/драйверы с выходами с 3 состояниями 20-SOIC от 0 до 70
Octal Buffers/Drivers With 3-State Outputs datasheet
PDF, 1.3 Мб, Версия: E, Файл опубликован: 2 авг 2002
Pin20
Package TypeDW
Package QTY25
МаркировкаAS240A
Width (мм)7.5
Length (мм)12.8
Thickness (мм)2.35
Max Height (мм)2.65
Bits8
F @ Nom Voltage(Max)125 Mhz
ICC @ Nom Voltage(Max)0.023 мА
Output Drive (IOL/IOH)(Max)-15/64 мА
Package Size: mm2:W x L20SOIC: 132 mm2: 10.3 x 12.8(SOIC) PKG
Schmitt TriggerNo
Technology FamilyAS
VCC(Max)5.5 В
VCC(Min)4.5 В
Voltage(Nom)5 В
tpd @ Nom Voltage(Max)9 нс
  • Advanced Schottky Load Management
    PDF, 277 Кб, Файл опубликован: 1 фев 1997
    Designers of high-speed systems that include advanced Schottky (AS) devices must consider the operating environment in their work. They must be aware of the individual device characteristics and their interaction with other devices. This document provides a detailed discussion of the waveform characteristics equivalent circuit models transmission line fanout and termination for AS load manageme
  • Semiconductors > Logic > Buffer/Driver/Transceiver > Inverting Buffer/Driver
На английском языке: Datasheet Texas Instruments SN74AS240ADW
