Datasheet Texas Instruments TMS320F28053PNQ — Даташит
СерияTMS320F28053
МодельTMS320F28053PNQ
Микроконтроллер Piccolo 80-LQFP от -40 до 125
TMS320F2805x Piccoloв„ў Microcontrollers datasheet
PDF, 1.6 Мб, Версия: B, Файл опубликован: 2 июл 2014
Pin8080
Package TypePNPN
Industry STD TermLQFPLQFP
JEDEC CodeS-PQFP-GS-PQFP-G
Package QTY119119
МаркировкаTMS320F28053PNQ
Width (мм)1212
Length (мм)1212
Thickness (мм)1.41.4
Pitch (мм).5.5
Max Height (мм)1.61.6
ADC16 Ch
ADC Resolution12-bit
CAN1
CPUC28x,CLA
Comparators7
FPUNo
Flash64 KB
Тактовая частота60 МГц
I2C1
Рабочий диапазон температурот -40 до 105,-40 до 125 C
PGA/VGA4
PWM14 Ch
Pin/Package80LQFP
QEP1
RAM20 KB
SPI1
Total Processing120 MIPS
UART3 SCI
  • JTAG Emulators/ Analyzers: C2000-GANG
    C2000 Gang Programmer
  • Evaluation Modules & Boards: TMDSRSLVR
    C2000 Resolver to Digital Conversion Kit
  • Evaluation Modules & Boards: TMDSSOLARUINVKIT
    Solar Micro Inverter Development Kit
  • Evaluation Modules & Boards: TMDSCNCD28027F
    controlCARD with Piccolo TMS320F28027FPTT, InstaSPINВ™-FOC enabled
  • Evaluation Modules & Boards: TMDSCNCD28054MISO
    controlCARD with Piccolo TMS320F28054MPNT, InstaSPIN-FOC and InstaSPIN-MOTION enabled
  • Evaluation Modules & Boards: TMDXDOCK28055
    Piccolo F2805x Experimenter Kit
  • Daughter Cards: TMDXCNCD28055ISO
    Piccolo F2805x Isolated USB controlCARD
  • Evaluation Modules & Boards: TMDXHVMTRKIT5X
    Piccolo F2805x High Voltage Motor Control Developer's Kit
  • JTAG Emulators/ Analyzers: TMDSEMU100V2U-20T
    XDS100v2 JTAG Debug Probe (20-pin cTI version)
  • JTAG Emulators/ Analyzers: TMDSEMU100V2U-14T
    XDS100v2 JTAG Debug Probe (14-pin TI version)
    XDS200 USB Debug Probe
  • Piccolo MCU CAN Module Operation Using the On-Chip Zero-Pin Oscillator (Rev. A)
    PDF, 43 Кб, Версия: A, Файл опубликован: 19 авг 2011
    CAN protocol imposes rather stringent requirements on its timing source, which are generally met by the provision of an external quartz crystal/oscillator. The TMS320C2803x/TMS320F2806x series of microcontrollers have an on-chip zero-pin oscillator that needs no external components. This application report describes how to use the CAN module with this oscillator to operate at the maximum bit rate
  • Using the CAN Piccolo Bootloader at High Temperature
    PDF, 33 Кб, Файл опубликован: 29 июн 2015
    The Controller Area Network (CAN) protocol requires strict tolerances from reference bit clocks, which are generally met using quartz crystal oscillators or ceramic resonators. The TMS320F2803x, TMS320F2805x, and TMS320F2806x microcontrollers use an on-chip zero-pin oscillator with no external components as a reference clock for the CAN bootloader. This oscillator's tolerance is sufficient at room
  • InstaSPIN(tm) BLDC Lab
    PDF, 1.4 Мб, Файл опубликован: 15 ноя 2011
    For this lab we are using the Three Phase BLDC Motor Kit with DRV8312 and Piccolo MCU (DRV8312-C2-KIT) (the DRV8302-HC-C2-KIT or DRV8301-HC-C2-KIT can also be used) with a Piccolo F28035 controlCARD subsystem to run the sensorless InstaSPIN BLDC technique.These are the tasks that must be done to spin motors:Make sure all physical connections and jumper settings on the kit
  • Programming Examples for the TMS320x28xx eCAN (Rev. B)
    PDF, 73 Кб, Версия: B, Файл опубликован: 12 сен 2017
    The TMS320x28xx series of Microcontrollers/Digital Signal Controllers feature an on-chip enhanced Controller Area Network (eCAN) module. This module is a full-CAN controller, compliant with CAN specification 2.0B. This application report contains several programming examples, supplemental to those in C2000Ware/controlSUITE, to illustrate how the eCAN module is set up for different modes of operati
  • Accelerators: Enhancing the Capabilities of the C2000 MCU Family Technical Brief (Rev. A)
    PDF, 155 Кб, Версия: A, Файл опубликован: 8 ноя 2016
    Engineers designing real-time control systems are constantly faced with the challenge of optimizing performance. These systems require minimal processing latency in order to meet the control loop performance specifications. At the heart of the control systems are math intensive algorithms which are used to calculate the control signals. Utilizing a microcontroller (MCU) that can quickly and effici
  • Serial Flash Programming of C2000 Microcontrollers (Rev. B)
    PDF, 387 Кб, Версия: B, Файл опубликован: 8 фев 2017
    Often times, embedded processors must be programmed in situations where JTAG is not a viable optionfor programming the target device. When this is the case, the engineer must rely on some type of serial programming solution. C2000 devices aid in this endeavor through their inclusion of several program loading utilities included in ROM. These utilities are useful, but only solve half of the progr
  • EEPROM Emulation With the TMS320F28xxx DSCs
    PDF, 407 Кб, Файл опубликован: 21 сен 2009
    Many applications require storing small quantities of system related data (e.g., calibration values, device configuration) in a non-volatile memory, so that it can be used or modified and reused even after power cycling the system. EEPROMs are primarily used for this purpose. EEPROMs have the ability to erase and write individual bytes of memory many times over and the programmed locations retain
  • Calculator for CAN Bit Timing Parameters
    PDF, 37 Кб, Файл опубликован: 22 мар 2016
    Controller Area Network (CAN) nodes use user-specified timing parameters to sample the asynchronous bitstream and recover the clock. These parameters are typically based on the frequency of the available reference oscillator. There may be several options available for a given frequency, and some of them will allow a looser oscillator tolerance than others. This application report details the creat
  • Programming External Nonvolatile Memory Using SDFlash for TMS320C28x Devices
    PDF, 2.0 Мб, Файл опубликован: 16 ноя 2009
    The C28xxx generation of microcontrollers can connect to external nonvolatile memory through a variety of interfaces including parallel, serial peripheral interface (SPI), and inter-integrated circuit (I2C). This application report discusses how to write drivers for your external nonvolatile memory to allow for in-place programming using SDFlash, an application provided by Spectrum Digital, Inc. A
  • TPS75005 Quick-Start Guide with C2000 Controllers
    PDF, 129 Кб, Файл опубликован: 17 янв 2012
    The TPS75005 is a complete power management solution for C2000 controllers from Texas Instruments. This document illustrates how to attach the TPS75005 to a C2000 controller.
Серия: TMS320F28053 (3)
  • Semiconductors > Microcontrollers (MCU) > Performance MCUs > Real-time Control > Piccolo F2802x/3x/5x/6x/7x
На английском языке: Datasheet Texas Instruments TMS320F28053PNQ
