Заказные клавиатуры Accord по вашему ТЗ
Datasheet ТI OPA2695IDR — Даташит
СерияOPA2695
МодельOPA2695IDR
Datasheet Texas Instruments OPA2695IDR
Сверхширокополосный операционный усилитель с токовой обратной связью и отключением 8-SOIC от -40 до 85
Dual, Ultra-Wideband, Current-Feedback Operational Amplifier with Disable datasheet
PDF, 1.4 Мб, Версия: A, Файл опубликован: 29 авг 2008
  • Wireline Data Transmission and Reception
    PDF, 191 Кб, Файл опубликован: 27 янв 2010
    Many types of wires are widely used to transmit data. Specifically, Category 3 and Category 5 (Cat3 and Cat5e, respectively)—also known as unshielded twisted pair or UTP lines—are now recommended for new telephone installations. Coaxial (coax) cables are used to distribute cable television (CATV) signals throughout a home. #12 and #14 American wire gauge (AWG) electric power distribution wire is a
  • Driving High-Speed ADCs: Circuit Topologies and System-Level Parameters (Rev. A)
    PDF, 327 Кб, Версия: A, Файл опубликован: 10 сен 2010
    This application report discusses the performance-related aspects of passive and active interfaces at the analog input of high-speed pipeline analog-to-digital converters (ADCs). The report simplifies the many possibilities into two main categories: passive and active interface circuits. The first section of the report gives an overview of equivalent models of buffered and unbuffered ADC input cir
  • Tuning in Amplifiers
  • Op Amp Performance Analysis
На английском языке: Datasheet Texas Instruments OPA2695IDR
Политика конфиденциальности
