Datasheet Texas Instruments OPA3684IDBQ — Даташит
СерияOPA3684
МодельOPA3684IDBQ
Маломощный операционный усилитель с тройной обратной связью по току и отключением 16-SSOP от -40 до 85
Low-Power, Triple Current Feedback Operational Amplifier with Disable datasheet
PDF, 1.3 Мб, Версия: C, Файл опубликован: 2 июл 2008
Pin16
Package TypeDBQ
Industry STD TermSSOP
Width (мм)3.9
Length (мм)4.9
Thickness (мм)1.5
Pitch (мм).64
Max Height (мм)1.75
2nd Harmonic(dBc)67
3rd Harmonic(dBc)70
@ MHz5
Acl, min spec gain(V/V)1
Additional FeaturesShutdown
Approx. Price (US$)2.75 | 1ku
АрхитектураBipolar
Current FB
BW @ Acl(MHz)210
CMRR(Min)(dB)53
CMRR(Typ)(dB)60
GBW(Typ)(MHz)210
Input Bias Current(Max)(pA)10000000
Iq per channel(Max)(mA)1.8
Iq per channel(Typ)(mA)1.7
Number of Channels(#)3
Offset Drift(Typ)(uV/C)12
Operating Temperature Range(C)-40 to 85
Output Current(Typ)(mA)120
Package GroupSSOP
Package Size: mm2:W x L (PKG)16SSOP: 19 mm2: 3.9 x 4.9(SSOP)
Rail-to-RailNo
Slew Rate(Typ)(V/us)820
Total Supply Voltage(Max)(+5V=5, +/-5V=10)12
Total Supply Voltage(Min)(+5V=5, +/-5V=10)5
Vn at Flatband(Typ)(nV/rtHz)3.7
Vos (Offset Voltage @ 25C)(Max)(mV)3.5
RoHSНе совместим
  • Evaluation Modules & Boards: DEM-OPA368XDBQ
    OPA368x Evaluation Fixture
    DEM-OPA368xD: Demonstration board
  • Evaluation Modules & Boards: DEM-OPA-SO-3B
    DEM-OPA-SO-3B
  • Evaluation Modules & Boards: DEM-OPA-SSOP-3B
    DEM-OPA-SSOP-3B
  • Current Feedback Amplifiers: Review, Stability Analysis, and Applications
    PDF, 53 Кб, Файл опубликован: 20 ноя 2000
    The majority of op amp circuits are closed-loop feedback systems that implement classical control theory analysis. Analog designers are comfortable with Voltage FeedBack (VFB) op amps in a closed-loop system and are familiar with the ideal op amp approximations feedback permit. This application bulletin will demonstrate how CFB op amps can be analyzed in a similar fashion. Once the closed-loop sim
  • Stabilizing Current-Feedback Op Amps While Optimizing Circuit Performance
    PDF, 280 Кб, Файл опубликован: 28 апр 2004
    Optimizing a circuit design with a current-feedback (CFB) op amp is a relatively straightforward task, once one understands how CFB op amps achieve stability. This application note explains a 2nd-order CFB model so that any designer can better understand the flexibility of the CFB op amp. This report also discusses stability analysis, the effects of parasitic components due to PCBs, optimization
  • Active filters using current-feedback amplifiers
    PDF, 227 Кб, Файл опубликован: 25 фев 2005
  • Expanding the usability of current-feedback amplifiers
    PDF, 215 Кб, Файл опубликован: 28 фев 2005
  • Tuning in Amplifiers
  • Op Amp Performance Analysis
На английском языке: Datasheet Texas Instruments OPA3684IDBQ
