Datasheet Texas Instruments BQ24401PWR — Даташит
СерияBQ24401
МодельBQ24401PWR
Импульсное зарядное устройство NiCd/NiMH аккумуляторов с клеммой dT/dt 8-TSSOP от -20 до 70
Programmable NiCd/NiMH Fast-Charge Management IC datasheet
PDF, 1.2 Мб, Версия: A, Файл опубликован: 8 мар 2010
Package TypePW
Industry STD TermTSSOP
Package QTY2000
Маркировка24401
Width (мм)4.4
Length (мм)3
Thickness (мм)1
Max Height (мм)1.2
Absolute Vin (safety rating)(Max)(7 В
Battery Charge Voltage(Max)8 В
Battery Charge Voltage(Min)0.95 В
Cell ChemistryNiCd,NiMH
Charge Current(Max)2 A
Control InterfaceStandalone (RC-Settable)
Control TopologySwitch-Mode Buck
Number of Series Cells1,2,3,4
Operating Vin(Max)6 В
Operating Vin(Min)4 В
Package GroupTSSOP
Package Size: mm2:W x L8TSSOP: 19 mm2: 6.4 x 3(TSSOP) PKG
Special FeaturesTemp Monitoring (Thermistor Pin)
USB FeatureN/A
  • U-504 Using the bq2000/T to Control Fast Charge (Rev. B)
    PDF, 193 Кб, Версия: B, Файл опубликован: 2 дек 2004
    The bq2000/T are programmable, monolithic ICs for fast-charge management of nickel cadmium, nickel metal-hydride, and lithium-ion batteries in single- or multichemistry applications. This application note discusses simple ways to select all necessary components to implement various switch-mode topologies. It also discusses how to configure the bq2000/T inputs to accomodate different appplication c
  • Semiconductors > Power Management > Battery Management Products > Battery Charger IC
На английском языке: Datasheet Texas Instruments BQ24401PWR
