Datasheet Texas Instruments OPA2188AIDR — Даташит
СерияOPA2188
МодельOPA2188AIDR
0.03ВµV/В°C, 6ВµV Vos, Low Noise, Rail-to-Rail Output, 36V Zero-Drift Operational Amplifier 8-SOIC -40 to 105
OPA2188 0.03-ОјV/В°C Drift, Low-Noise, Rail-to-Rail Output, 36-V, Zero-Drift Operational Amplifiers datasheet
PDF, 1.3 Мб, Версия: C, Файл опубликован: 16 май 2016
Pin88
Package TypeDD
Industry STD TermSOICSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY25002500
CarrierLARGE T&RLARGE T&R
Маркировка2188OPA2188
Width (мм)3.913.91
Length (мм)4.94.9
Thickness (мм)1.581.58
Pitch (мм)1.271.27
Max Height (мм)1.751.75
Additional FeaturesEMI Hardened,Zero Drift
АрхитектураCMOS
CMRR(Min)106 дБ
CMRR(Typ)114 дБ
GBW(Typ)2 МГц
Input Bias Current(Max)850 pA
Iq per channel(Max)0.44 мА
Iq per channel(Typ)0.385 мА
Количество каналов2
Offset Drift(Typ)0.03 uV/C
Output Current(Typ)18 мА
Rail-to-RailIn to V-,Out
Slew Rate(Typ)0.8 V/us
Total Supply Voltage(Min)4 +5V=5, +/-5V=10
Vn at 1kHz(Typ)8.8 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)0.025 мВ
  • Evaluation Modules & Boards: OPAMPEVM
    Universal Operational Amplifier Evaluation Module
  • DC Controlled Low Pass Filter
    PDF, 410 Кб, Файл опубликован: 9 мар 2017
    This application report describes a dc controlled low-pass filter circuit using LM3046. The cut off frequency can be varied by varying the capacitance of the low-pass filter.
  • EMI Rejection Ratio of Operational Amplifiers (With OPA333 and OPA333-Q1 as an E (Rev. A)
    PDF, 372 Кб, Версия: A, Файл опубликован: 1 июл 2015
    This application report introduces the concept of electromagnetic interference rejection ratio (EMIRR IN+) as a measure of the immunity of an operational amplifier to responding to electromagnetic interference (EMI). Texas Instruments has developed the ability to accurately measure and quantify the immunity of an operational amplifier over a broad frequency spectrum extending from 10 MHz to 6 GHz.
  • Analog linearization of resistance temperature detectors
    PDF, 152 Кб, Файл опубликован: 9 ноя 2011
  • 4Q 2011 Issue Analog Applications Journal
    PDF, 943 Кб, Файл опубликован: 9 ноя 2011
  • Offset Correction Methods: Laser Trim, e-Trim, and Chopper (Rev. A)
    PDF, 795 Кб, Версия: A, Файл опубликован: 20 июл 2017
  • Tuning in Amplifiers
  • Op Amp Performance Analysis
Серия: OPA2188 (4)
На английском языке: Datasheet Texas Instruments OPA2188AIDR
