Datasheet Texas Instruments TL750L12CKC — Даташит
Серия | TL750L12 |
Модель | TL750L12CKC |
LDO с одним выходом, 150 мА, фиксированный (12,0 В), низкий ток покоя, защита от сброса нагрузки 60 В 3-TO-220 0–125
Datasheet
![]() 7 предложений от 7 поставщиков Чип стабилизации напряжения, Single Output LDO, 150mA, Fixed(12V), Low Quiescent Current, 60V Load Dump Protection 3-TO-220 0 to 125 | |||
TL750L12CKC Rochester Electronics | 57 ₽ | ||
TL750L12CKC Texas Instruments | 61 ₽ | ||
TL750L12CKC Texas Instruments | 143 ₽ | ||
TL750L12CKC | 175 ₽ |
Pin | 3 |
Package Type | KC |
Industry STD Term | TO-220 |
JEDEC Code | R-PSFM-T |
Width (мм) | 9.02 |
Length (мм) | 10.17 |
Thickness (мм) | 4.58 |
Pitch (мм) | 2.54 |
Max Height (мм) | 4.7 |
Mechanical Data | Скачать |
Accuracy(%) | 4 |
Additional Features | Enable Overcurrent Protection Thermal Shutdown |
Approx. Price (US$) | 0.20 | 1ku |
Fixed Output Options(V) | 12 |
Iout(Max)(A) | 0.15 |
Iq(Typ)(mA) | 1 |
Operating Temperature Range(C) | 0 to 125 |
Output Capacitor Type | Cap Free Non-Ceramic |
Output Options | Fixed Output |
Package Group | SOIC TO-92 |
Package Size: mm2:W x L (PKG) | See datasheet (TO-220) See datasheet (PDIP) |
Rating | Catalog |
Regulated Outputs(#) | 1 |
Vdo(Typ)(mV) | 600 |
Vin(Max)(V) | 26 |
Vin(Min)(V) | 13 |
Vout(Max)(V) | 12 |
Vout(Min)(V) | 12 |
RoHS | Не совместим |
- Technical Review of Low Dropout Voltage Regulator Operation And PerformancePDF, 284 Кб, Файл опубликован: 30 авг 1999
This application report provides a technical review of low dropout (LDO) voltage regulators and describes fundamental concepts including dropout voltage quiescent current and topologies. The report also includes detailed discussions of load/line regulation efficiency frequency response range of stable ESR and accuracy of LDO voltage regulators. - Fundamental Theory of PMOS LDO Voltage RegulatorsPDF, 66 Кб, Файл опубликован: 7 май 1999
This report presents a fundamental understanding on the theory of low-dropout voltage regulators using a PMOS FET as the pass element to adjust the output current to the load requirements. - LDO PSRR Measurement Simplified (Rev. A)PDF, 131 Кб, Версия: A, Файл опубликован: 9 авг 2017
This applicationreportexplainsdifferentmethodsof measuringthe PowerSupplyRejectionRatio(PSRR)of a Low-Dropout(LDO)regulatorand includesthe prosand consof thesemeasuringmethods - LDO Noise Demystified (Rev. A)PDF, 785 Кб, Версия: A, Файл опубликован: 9 авг 2017
Серия: TL750L12 (7)
- TL750L12CKC TL750L12CP TL750L12QD TL750L12QDR TL750L12QKC TL750L12QLP TL750L12QP
