Datasheet Texas Instruments LP8556TMX-E04/NOPB — Даташит
СерияLP8556
МодельLP8556TMX-E04/NOPB
6-канальный высокоэффективный драйвер светодиодной подсветки 20-DSBGA от -30 до 85
LP8556 High-Efficiency LED Backlight Driver for Tablets datasheet
PDF, 1.2 Мб, Версия: I, Файл опубликован: 22 мар 2016
IC LED DRIVER RGLTR DIM 20DSBGA. LED Driver IC 6 Output DC DC Regulator Step-Up (Boost) PWM Dimming 20mA 20-DSBGA (2.04x1.78)....
LP8556TMX-E04/NOPB
Hi-Tech Circuit Group
LP8556TMX-E04/NOPB
LP8556TMX-E04/NOPB
LP8556TMX-E04/NOPB
Pin20
Package TypeYFQ
Industry STD TermDSBGA
JEDEC CodeR-XBGA-N
Package QTY3000
Маркировка56E4
Thickness (мм).42
Pitch (мм).4
Max Height (мм).675
Количество каналов6
Duty Cycle(Max)100 %
LED60
LED Current Per Channel50 мА
Рабочий диапазон температурот -30 до 85 C
Package GroupDSBGA
Peak Efficiency95 %
Shutdown Current(Typ)0.1 uA
Special FeaturesI2C Control
Switching Frequency(Max)1250 kHz
TopologyBoost
ТипInductive
Vin(Max)20 В
Vin(Min)2.7 В
Vout(Max)48 В
Vout(Min)7 В
  • Evaluation Modules & Boards: LP8556TM-EVM
    LP8556TM-EVM
  • Evaluation Modules & Boards: LP8556SQ-EVM
    LP8556SQ-EVM
  • AN-1112 DSBGA Wafer Level Chip Scale Package (Rev. AG)
    PDF, 13.7 Мб, Версия: AG, Файл опубликован: 12 авг 2015
  • Increasing Full-Load Efficiency of a Backlight Driver
    PDF, 1.2 Мб, Файл опубликован: 5 июн 2013
    This application report discusses a way to increase the efficiency of the boost converter in a backlightdriver by reducing conduction and AC losses in the inductor, thereby increasing the overall efficiency ofthe backlight driver at higher loads.
  • Inductor Selection in Boost Converters for LCD Backlight Applications
    PDF, 764 Кб, Файл опубликован: 24 окт 2016
    White LED drivers for LCD back-light applications are often designed for battery-powered devices. This makes circuit size and efficiency crucial. Because of this, selecting the optimal inductor is one of the mostimportant aspects of the design. This application note discusses the important parameters of the inductorand how to select the right inductor for the application.
  • Schottky Diode Selection in Asynchronous Boost Converters
    PDF, 491 Кб, Файл опубликован: 6 сен 2016
    Asynchronous boost converters require a Schottky diode as the rectifying element due to the diode's lowforward voltage and fast turn-on time. Because of these characteristics asynchronous boost converterscan have as good as, or better efficiency, than synchronous boost converters. This is especially true whenthe boost conversion ratios (VOUT/VIN) are high, and the Schottky diode conduction t
  • Power Budget for Backlight Drivers
    PDF, 592 Кб, Файл опубликован: 27 июн 2013
    This application report discusses the Power Budget of an LED backlight driver. It provides experimental and theoretical methods of calculating different losses associated with LED backlight drivers. It also provides an analytical discussion on behavior of different losses vs brightness levels.
  • Semiconductors > Power Management > LED Driver > Backlight LED Driver
LP8556TMXE04/NOPB, LP8556TMX E04/NOPB
На английском языке: Datasheet Texas Instruments LP8556TMX-E04/NOPB
