Datasheet Texas Instruments TPS79925DDCT — Даташит
СерияTPS799
МодельTPS79925DDCT
Линейный стабилизатор 5-SOT-23-THIN от -40 до 125, 200 мА, низкий ток покоя, сверхнизкий уровень шума, высокий PSRR и малое падение напряжения.
TPS799 200-mA, Low-Quiescent Current, Ultralow Noise, High-PSRR Low-Dropout Linear Regulator datasheet
PDF, 1.3 Мб, Версия: K, Файл опубликован: 5 янв 2011
Pin5
Package TypeDDC
Industry STD TermSOT-23-THIN
Package QTY250
CarrierSMALL T&R
МаркировкаAWW
Width (мм)1.6
Length (мм)2.9
Thickness (мм).87
Pitch (мм).95
Max Height (мм)1.1
Точность2 %
Fixed Output Options1.2,1.25,1.3,1.5,1.8,1.85,1.9,1.95,2,2.1,2.5,2.6,2.7,2.75,2.8,2.85,3,3.15,3.2,3.3,4.2,4.5 В
Iout(Max)0.2 A
Iq(Typ)0.04 мА
Noise29 uVrms
Output Capacitor TypeCeramic
PSRR @ 100KHz38 дБ
Package GroupSOT-23-THIN
Package Size: mm2:W x L5SOT-23-THIN: 8 mm2: 2.8 x 2.9(SOT-23-THIN) PKG
Regulated Outputs1
Special FeaturesEnable
Thermal Resistance ОёJA74 В°C/W
Vdo(Typ)100 мВ
Vin(Max)6.5 В
Vin(Min)2.7 В
Vout(Max)6.5 В
Vout(Min)1.2 В
  • Evaluation Modules & Boards: TPS799XXEVM-105
    TPS799xx Evaluation Module
  • Understanding LDO Dropout
    PDF, 52 Кб, Файл опубликован: 9 май 2005
    Not all low dropout (LDO) linear regulator data sheets provide the voltage dropout information needed for all applications. This application report shows a designer how to use an LDO data sheet's specified dropout performance to determine the dropout voltage at other operating conditions.
  • Using Thermal Calculation Tools for Analog Components
    PDF, 1.1 Мб, Файл опубликован: 2 сен 2010
    This document provides general guidance on the use of toolsand calculations for thermal estimates of component operating temperatures for analog devices. Of particularfocus are components with direct thermal paths to the PCB which is common for components which need a low thermal resistance to manage the dissipated power. This document provides practical considerations for estimation of o
На английском языке: Datasheet Texas Instruments TPS79925DDCT
