Datasheet Texas Instruments DAC081C085CIMMX/NOPB — Даташит
Серия | DAC081C085 |
Модель | DAC081C085CIMMX/NOPB |
8-битный ЦАП Micro Pwr с I2C-совместимым интерфейсом и внешним опорным сигналом 8-VSSOP от -40 до 125
DAC081C08x 8-Bit Micro Power Digital-to-Analog Converter With An I2C-Compatible Interface datasheet
PDF, 1.8 Мб, Версия: F, Файл опубликован: 23 май 2016
Pin | 8 |
Package Type | DGK |
Industry STD Term | VSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 3500 |
Carrier | LARGE T&R |
Маркировка | X92C |
Width (мм) | 3 |
Length (мм) | 3 |
Thickness (мм) | .97 |
Pitch (мм) | .65 |
Max Height (мм) | 1.07 |
Mechanical Data | Скачать |
Code to Code Glitch(Typ) | 12 nV-sec |
DAC Architecture | String |
DAC Channels | 1 |
Gain Error(Max) | 0.7 %FSR |
INL(Max) | 0.6 +/-LSB |
Interface | I2C |
Output Range Max. | 5.5 mA/V |
Тип выхода | Buffered Voltage |
Package Group | VSSOP |
Package Size: mm2:W x L | 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) PKG |
Power Consumption(Typ) | 0.38 mW |
Rating | Catalog |
Reference: Type | Ext |
Разрешение | 8 Bits |
Sample / Update Rate | 0.18 MSPS |
Время установления | 4.5 µs |
Special Features | N/A |
Zero Code Error(Typ) | 10 мВ |
- AN-2001 Daisy Chaining Precision DACs (Rev. A)PDF, 75 Кб, Версия: A, Файл опубликован: 1 май 2013
It is not uncommon for the system designer to face a quagmire of reconciling the system complexity withthe desire to keep the system footprint small. One specific example that often arises in the context ofsmall system footprint is the need for single master controller to communicate with a number of slavedevices. This is not much of a problem if the master controller has multiple I/O resour
Серия: DAC081C085 (2)
- DAC081C085CIMM/NOPB DAC081C085CIMMX/NOPB
- Semiconductors > Data Converters > Digital-to-Analog Converters (DACs) > Precision DACs (=<10MSPS)
