Datasheet Texas Instruments CD54HC157F3A — Даташит
СерияCD54HC157
МодельCD54HC157F3A
Высокоскоростные мультиплексоры CMOS Logic Quad с 2 входами, 16-CDIP от -55 до 125
CD54/74HC157, CD54/74HCT157, CD54/74HC158, CD54/74HCT158 datasheet
PDF, 449 Кб, Версия: C, Файл опубликован: 13 окт 2003
19 предложений от 17 поставщиков
Микросхема Логический чип, Multiplexer 1Element CMOS 8IN 16Pin CDIP Tube
CD54HC157F3A
от 2 530 ₽
TradeElectronics
CD54HC157F3A*
CD54HC157F3A
727GS
CD54HC157F3A(5962-8606101EA)
Pin1616
Package TypeJJ
Industry STD TermCDIPCDIP
JEDEC CodeR-GDIP-TR-GDIP-T
Package QTY11
CarrierTUBETUBE
Маркировка5962-8606101EACD54HC157F3A
Width (мм)6.926.92
Length (мм)19.5619.56
Thickness (мм)4.574.57
Pitch (мм)2.542.54
Max Height (мм)5.085.08
Количество каналов4
F @ Nom Voltage(Max)28 Mhz
ICC @ Nom Voltage(Max)0.08 мА
Package GroupCDIP
RatingMilitary
Schmitt TriggerNo
Technology FamilyHC
VCC(Max)6 В
VCC(Min)2 В
Voltage(Nom)3.3,5 В
tpd @ Nom Voltage(Max)10 нс
RoHSSee ti.com
  • Selecting the Right Texas Instruments Signal Switch
    PDF, 769 Кб, Файл опубликован: 7 сен 2001
    Texas Instruments offers a wide variety of electronic switches (digital analog bilateral bilateral analog) in a variety of families including CBT CBTLV HC LV and LVC. Depending on the application the right solution may be an analog switch that passes digital signals or vice versa. This application report summarizes the various switching technologies and provides considerations for choosi
Серия: CD54HC157 (2)
  • Semiconductors > Space & High Reliability > Logic Products > Specialty Logic Products > Decoders/Encoders/Multiplexers
На английском языке: Datasheet Texas Instruments CD54HC157F3A
