Datasheet Texas Instruments TMS320C541PZ2-40 — Даташит
СерияTMS320C541
МодельTMS320C541PZ2-40
Цифровой сигнальный процессор 100-LQFP
TMS320C54x, LC54x, VC54x Fixed-Point Digital Signal Processors datasheet
PDF, 1.6 Мб, Версия: C, Файл опубликован: 30 мар 1999
Pin100100
Package TypePZPZ
Industry STD TermLQFPLQFP
JEDEC CodeS-PQFP-GS-PQFP-G
МаркировкаTMS320C541PZ2-40
Width (мм)1414
Length (мм)1414
Thickness (мм)1.41.4
Pitch (мм).5.5
Max Height (мм)1.61.6
RoHSНе совместим
  • Evaluation Modules & Boards: TMDSDSK5416
    TMS320C5416 DSP Starter Kit (DSK)
  • Extending Fixed-Point Dynamic Ranges
    PDF, 35 Кб, Файл опубликован: 1 июн 1997
    In many advanced control problems such as state estimators, Kalman filters and some high Q filters, the dynamic range/accuracy of the coefficient can sometimes be beyond the range of a Q15 number while the data value can be typically represented as a Q15 number.This document discusses how you can extend the fixed-point math dynamic range beyond the range of a Q15 number with a minimum of instr
  • Emulator Processor Access Timeout
    This document discusses what would cause a "processor access timeout" message in the XDS510 emulator command window. Also discussed are issues related to the validity of the error message information.
Серия: TMS320C541 (2)
  • Semiconductors > Processors > Digital Signal Processors > C5000 DSP > Other C5000 DSP
TMS320C541PZ240, TMS320C541PZ2 40
На английском языке: Datasheet Texas Instruments TMS320C541PZ2-40
