Datasheet Texas Instruments TPA3117D2RHBR — Даташит
СерияTPA3117D2
МодельTPA3117D2RHBR
Стереоусилитель класса D без фильтров, 15 Вт 32-VQFN от -40 до 85
15W Filter-Free Stereo Class-D Amplifier datasheet
PDF, 1.2 Мб, Файл опубликован: 14 окт 2010
30 предложений от 15 поставщиков
Микросхема Усилитель звуковой частоты, Audio Amp Speaker 2CH Stereo 15W Class-D 32Pin VQFN EP T/R Audio Amp Speaker 2CH Stereo 15W...
TPA3117D2RHBR
140 ₽
TPA3117D2RHBR
164 ₽
IC Home
TPA3117D2RHBR
229 ₽
TradeElectronics
TPA3117D2RHBR
Pin32
Package TypeRHB
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY3000
МаркировкаTPA3117
Width (мм)5
Length (мм)5
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
Analog Supply (V)26 Min
Audio Input TypeAnalog
Closed/Open LoopClosed
Control InterfaceHardware
Package GroupVQFN
Package Size: mm2:W x L32VQFN: 25 mm2: 5 x 5(VQFN) PKG
Power Stage Supply(Max)26 В
Power Stage Supply(Min)8 В
Power to Bridge Tied Load(Max)15 W
Speaker Channels2 Max
Supported Bridge Tied Load(Min)4 Ohms
  • AN-1737 Managing EMI in Class D Audio Applications (Rev. A)
    PDF, 140 Кб, Версия: A, Файл опубликован: 1 май 2013
    Electromagnetic interference (EMI) is an unwanted disturbance caused in an electrical circuit byelectromagnetic radiation emitted from an external source. The disturbance may interrupt, obstruct, orotherwise degrade the effective performance of the circuit.
  • AN-1849 An Audio Amplifier Power Supply Design (Rev. B)
    PDF, 1.9 Мб, Версия: B, Файл опубликован: 1 май 2013
    This application report provides design information for a power supply for use with our newest offering of high-performance, ultra high-fidelity audio amplifier input stage ICs.
  • Guidelines for Measuring Audio Power Amplifier Performance
    PDF, 765 Кб, Файл опубликован: 30 окт 2001
    This application note provides guidelines for measuring the date sheet parameters of Texas Instruments audio power amplifiers (APAs) using prefabricated evaluation modules (EVMs). The primary equipment used for the measurements consists of the System Two audio measurement system by Audio Precision , a digital multimeter (DMM), and a dc power supply.
Серия: TPA3117D2 (2)
  • Semiconductors > Audio > Mid-Power Audio Amplifiers (10-50W) > Analog Input Amplifiers
На английском языке: Datasheet Texas Instruments TPA3117D2RHBR
