Datasheet Texas Instruments OPA2681N-12 — Даташит
СерияOPA2681
МодельOPA2681N-12
Широкополосный операционный усилитель SpeedPlus™ с токовой обратной связью и отключением 14-SOIC
OPA2681: SpeedPlus Dual Wideband, Current Feedback Op Amp with Disable (Rev. A)
PDF, 371 Кб, Версия: A, Файл опубликован: 5 янв 2001
Pin14
Package TypeD
Width (мм)3.91
Length (мм)8.65
Thickness (мм)1.58
Max Height (мм)1.75
RoHSНе совместим
  • Evaluation Modules & Boards: DEM-OPA268XN
    DEM-OPA268xN: Demonstration Fixture
  • Evaluation Modules & Boards: DEM-OPA268XU
    DEM-OPA268xU: Demonstration Fixture
  • Tuning in Amplifiers
  • The Current-Feedback Op Amp: A High-Speed Building Block
    PDF, 117 Кб, Файл опубликован: 2 окт 2000
    Although current-feedback amplifiers (CFAs) have been in use for quite some time, there is a reluctance to view them in the same light as voltage-feedback amplifiers (VFAs). For instance, the gain-bandwidth curve of VFAs has a parallel in a transimpedance-bandwidth curve for CFAs. This parameter can be used to determine the closed-loop behavior of the CFA in same way that GBW can for the VFA. Not
  • Op Amp Performance Analysis
OPA2681N12, OPA2681N 12
На английском языке: Datasheet Texas Instruments OPA2681N-12
