Datasheet ТI THS6072IDGNR — Даташит
| Серия | THS6072 |
| Модель | THS6072IDGNR |
Дифференциальный приемник ADSL малой мощности 8-MSOP-PowerPAD от -40 до 85
Low-Power ADSL Differntial Receivers datasheet
PDF, 1.2 Мб, Версия: B, Файл опубликован: 25 июн 2001
- Active Output Impedance for ADSL Line DriversPDF, 636 Кб, Файл опубликован: 26 ноя 2002
Signal termination is very common in bidirectional communication systems. Termination allows for receiving signals while transmitting different signals at the same time. With the increasing popularity of asymmetrical digital subscriber lines (ADSL), the requirement for a low power line driver amplifier combined with line termination becomes a very difficult goal. This application note examines the - Noise Analysis for High Speed Op Amps (Rev. A)PDF, 256 Кб, Версия: A, Файл опубликован: 17 янв 2005
Серия: THS6072 (7)
- THS6072CD THS6072CDGN THS6072CDGNR THS6072CDGNRG4 THS6072ID THS6072IDG4 THS6072IDGNR
- Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > High-Speed Op Amps (>=50MHz)
