Оптопары и оптореле Megawin
Datasheet Texas Instruments LMV932MA/NOPB — Даташит
СерияLMV932-N
МодельLMV932MA/NOPB
Двойные 1,8 В операционные усилители RRIO 8-SOIC от -40 до 125
LMV93x-N Single, Dual, Quad 1.8-V, RRIO Operational Amplifiers datasheet
PDF, 1.7 Мб, Версия: P, Файл опубликован: 7 май 2017
Pin88
Package TypeDD
Industry STD TermSOICSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY9595
CarrierTUBETUBE
Маркировка32MALMV9
Width (мм)3.913.91
Length (мм)4.94.9
Thickness (мм)1.581.58
Pitch (мм)1.271.27
Max Height (мм)1.751.75
Additional FeaturesN/A
АрхитектураBipolar
CMRR(Min)60 дБ
CMRR(Typ)86 дБ
GBW(Typ)1.5 МГц
Input Bias Current(Max)35000 pA
Iq per channel(Max)0.23 мА
Iq per channel(Typ)0.116 мА
Количество каналов2
Offset Drift(Typ)5.5 uV/C
Output Current(Typ)65 мА
Rail-to-RailIn,Out
Slew Rate(Typ)0.42 V/us
Total Supply Voltage(Max)5.5 +5V=5, +/-5V=10
Total Supply Voltage(Min)1.8 +5V=5, +/-5V=10
Vn at 1kHz(Typ)50 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)5.5 мВ
  • Effect of Heavy Loads on Accuracy and Linearity of Op Amp Circuits (Rev. B)
    PDF, 81.7 Мб, Версия: B, Файл опубликован: 22 апр 2013
    This application report discusses the effect of heavy loads on the accuracy and linearity of operationalamplifier circuits.
  • AN-1515 A Comprehensive Study of the Howland Current Pump (Rev. A)
    PDF, 165 Кб, Версия: A, Файл опубликован: 26 апр 2013
    It is well known to analog experts that you can use the positive and negative inputs of an operationalamplifier to make a high-impedance current source (current pump) using a conventional operationalamplifier (op amp). This basic circuit can put out both + and - output current (or zero current) into variousloads. The theory is simple. But the practical problems involved are not so simple or
На английском языке: Datasheet Texas Instruments LMV932MA/NOPB
