Линейка продуктов KEEN SIDE
Datasheet Texas Instruments CD74HC139MT — Даташит
СерияCD74HC139
МодельCD74HC139MT
Высокоскоростные CMOS-логики, двойные линейные декодеры/демультиплексоры 2–4, 16-SOIC, от -55 до 125
CD54HC139, CD74HC139, CD54HCT139, CD74HCT139 datasheet
PDF, 450 Кб, Версия: D, Файл опубликован: 13 окт 2003
АЦП азиатских производителей
Pin16
Package TypeD
Package QTY250
CarrierSMALL T&R
МаркировкаHC139M
Width (мм)3.91
Length (мм)9.9
Thickness (мм)1.58
Max Height (мм)1.75
Approx. Price (US$)0.19 | 1ku
Bandwidth(MHz)28
Bits(#)4
Channels(#)2
Configuration2:4
Digital input leakage(Max)(uA)5
ESD Charged Device Model(kV)0.75
ESD HBM(kV)2
F @ Nom Voltage(Max)(Mhz)28
FunctionDecoder/Demultiplexer
ICC @ Nom Voltage(Max)(mA)0.08
Operating Temperature Range(C)-55 to 125
Output Drive (IOL/IOH)(Max)(mA)5.2/-5.2
Schmitt TriggerNo
Technology FamilyHC
ТипStandard
VCC(Max)(V)6
VCC(Min)(V)2
Voltage(Nom)(V)3.3
5
tpd @ Nom Voltage(Max)(ns)36
  • Selecting the Right Texas Instruments Signal Switch
    PDF, 769 Кб, Файл опубликован: 7 сен 2001
    Texas Instruments offers a wide variety of electronic switches (digital analog bilateral bilateral analog) in a variety of families including CBT CBTLV HC LV and LVC. Depending on the application the right solution may be an analog switch that passes digital signals or vice versa. This application report summarizes the various switching technologies and provides considerations for choosi
  • Semiconductors > Switches and Multiplexers > Buffered Encoders and Decoders
На английском языке: Datasheet Texas Instruments CD74HC139MT
