Datasheet Texas Instruments TMS320LF2406PZA — Даташит
СерияTMS320LF2406
МодельTMS320LF2406PZA
16-битный DSP с фиксированной запятой и Flash 100-LQFP от -40 до 85
Pin100
Package TypePZ
Industry STD TermLQFP
JEDEC CodeS-PQFP-G
Width (мм)14
Length (мм)14
Thickness (мм)1.4
Pitch (мм).5
Max Height (мм)1.6
RoHSНе совместим
  • DSP Solution for Permanent Magnet Synchronous Motor
    PDF, 210 Кб, Файл опубликован: 1 янв 1996
    This document presents a solution to control a permanent magnet synchronous motor using the TMS320C24x. This new family of DSPs enables cost-effective design of intelligent controllers for brushless motors which can fulfill enhanced operations, consisting of fewer system components, lower system cost and increased performances. The control method presented relies on the field orientated control (F
  • DSP Solution for AC Induction Motor
    PDF, 183 Кб, Файл опубликован: 1 янв 1996
    The Motor Control industry is a strong aggressive sector. Each industry to remain competitive, must reduce costs but also has to answer to power consumption reduction and EMI radiation reduction issues imposed by governments and power plant lobbies. The results of these constraining factors are the need of enhanced algorithms. DSP technology allows to achieve both, a high level of performance as
  • Implementation of a Speed Controlled Brushless DC Drive Using TMS320F240
    PDF, 157 Кб, Файл опубликован: 1 янв 1997
    The DSP Controller TMS320F240 from Texas Instruments is suitable for a wide range of motor drives. TMS320F240 provides a single chip solution by integrating on-chip not only a high computational power but, also, all the peripherals necessary for electric motor control. The main benefits are increased system reliability and cost reduction of the overall system. The present application note describ
Серия: TMS320LF2406 (2)
  • Semiconductors > Microcontrollers (MCU) > Performance MCUs > Real-time Control > C24x 16-bit Series
На английском языке: Datasheet Texas Instruments TMS320LF2406PZA
