Datasheet Texas Instruments UC1526J — Даташит
СерияUC1526
МодельUC1526J
Регулирующий широтно-импульсный модулятор 18-CDIP от -55 до 125
Regulating Pulse Width Modulator datasheet
PDF, 609 Кб, Файл опубликован: 5 сен 1999
Pin18
Package TypeJ
Industry STD TermCDIP
JEDEC CodeR-GDIP-T
Package QTY1
МаркировкаUC1526J
Width (мм)6.92
Length (мм)23.1
Thickness (мм)4.57
Pitch (мм)2.54
Max Height (мм)5.08
Control MethodVoltage
Duty Cycle(Max)50 %
Frequency(Max)400 kHz
Frequency(Min)0.01 kHz
Package GroupCDIP
RatingMilitary
Special FeaturesError Amplifier,Soft Start,Synchronization Pin,Multi-topology
TopologyBoost,Flyback,Forward,Full-Bridge,Half-Bridge,Push-Pull
UVLO Thresholds On/Off4.4/4.2 В
Vin(Max)35 В
Vin(Min)8 В
RoHSSee ti.com
  • DN-62 Switching Power Supply Topology Voltage Mode vs. Current Mode
    PDF, 66 Кб, Файл опубликован: 5 сен 1999
    This design note explains the differences between voltage-mode and current-mode switching power supply topologies. It includes a circuit diagram for each mode and suggests criteria for choosing which mode to use.
Серия: UC1526 (3)
  • Semiconductors > Space & High Reliability > Power Management Products > Offline and Isolated DC/DC Controller and Converter
На английском языке: Datasheet Texas Instruments UC1526J
