Datasheet Texas Instruments INA114BU/1K — Даташит
СерияINA114
МодельINA114BU/1K
Прецизионный инструментальный усилитель 16-SOIC
Precision Instrumentation Amplifier datasheet
PDF, 749 Кб, Файл опубликован: 27 сен 2000
Pin16
Package TypeDW
Package QTY1000
МаркировкаINA114BU
Width (мм)7.5
Length (мм)10.3
Thickness (мм)2.35
Max Height (мм)2.65
Bandwidth at Min Gain(Typ)1 МГц
CMRR(Min)110 дБ
Gain Error (+/-)(Max)2 %
Gain Non-Linearity (+/-)(Max)0.002 %
Gain(Max)10000 V/V
Gain(Min)1 V/V
Input Bias Current (+/-)(Max)2 нА
Input Offset (+/-)(Max)50 uV
Input Offset Drift (+/-)(Max)0.25 uV/C
Iq(Typ)2.2 мА
Noise at 0.1 Hz - 10 Hz(Typ)0.4 uVpp
Noise at 1kHz(Typ)(nV/rt11 Hz
Количество каналов1
Package Size: mm2:W x L16SOIC: 106 mm2: 10.3 x 10.3(SOIC) PKG
Vs(Max)36 В
Vs(Min)4.5 В
  • Use Low-Impedance Bridges on 4-20mA Current Loop
    PDF, 27 Кб, Файл опубликован: 27 сен 2000
    If you need more transducer excitation current than is available on a standard 4-20mA 2-wire current loop, consider a 3-wire transmitter. A 2-wire 4-20mA transmitter uses the same two wires for signal and power. Part of the 4mA minimum loop current is used to power the transmitter circuitry. The remaining current can be used for transducer excitation. In some applications even the entire 4mA is no
  • Semiconductors > Amplifiers > Instrumentation Amplifiers
На английском языке: Datasheet Texas Instruments INA114BU/1K
