Datasheet Texas Instruments THS3121CDR — Даташит
СерияTHS3121
МодельTHS3121CDR
Одиночный, малошумящий, высокопроизводительный усилитель с токовой обратной связью, 475 мА, 8-SOIC -40–85
Low-Noise, High-Output Drive, Current Feedback Operational Amplifiers datasheet
PDF, 1.3 Мб, Версия: E, Файл опубликован: 12 окт 2009
Package TypeD
Package QTY2500
Маркировка3121C
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
2nd Harmonic(dBc)51
3rd Harmonic(dBc)50
@ MHz10
Acl, min spec gain(V/V)1
Additional FeaturesN/A
Approx. Price (US$)2.48 | 1ku
АрхитектураBipolar
Current FB
BW @ Acl(MHz)130
CMRR(Min)(dB)63
CMRR(Typ)(dB)70
GBW(Typ)(MHz)130
Input Bias Current(Max)(pA)4000000
Iq per channel(Max)(mA)4.25
Iq per channel(Typ)(mA)3.5
Number of Channels(#)1
Offset Drift(Typ)(uV/C)10
Operating Temperature Range(C)-40 to 85
Output Current(Typ)(mA)475
Package Size: mm2:W x L (PKG)8SOIC: 29 mm2: 6 x 4.9(SOIC)
Rail-to-RailNo
Slew Rate(Typ)(V/us)1500
Total Supply Voltage(Max)(+5V=5, +/-5V=10)30
Total Supply Voltage(Min)(+5V=5, +/-5V=10)10
Vn at Flatband(Typ)(nV/rtHz)2.5
Vos (Offset Voltage @ 25C)(Max)(mV)10
  • Evaluation Modules & Boards: THS3111EVM
    THS3111 Evaluation Module
  • Evaluation Modules & Boards: THS3120EVM
    THS3120 Evaluation Module
  • Evaluation Modules & Boards: THS3110EVM
    THS3110 Evaluation Module
  • Active filters using current-feedback amplifiers
    PDF, 227 Кб, Файл опубликован: 25 фев 2005
  • Expanding the usability of current-feedback amplifiers
    PDF, 215 Кб, Файл опубликован: 28 фев 2005
  • Wideband Complementary Current Output DAC Single-Ended Interface
    PDF, 597 Кб, Файл опубликован: 21 июн 2005
    High-speed digital-to-analog converters (DACs) most often use a transformer-coupled output stage. In applications where this configuration is not practical, a single op ampdifferential to single-ended stage has often been used. This application note steps through the exact design equations required to achieve gain matching from each output as well as a matched input impedance to each of the DA
На английском языке: Datasheet Texas Instruments THS3121CDR
