Datasheet Texas Instruments UC2834J — Даташит
СерияUC2834M
МодельUC2834J
Высокоэффективный линейный регулятор 16-CDIP от -40 до 85
High Efficiency Linear Regulator datasheet
PDF, 1.1 Мб, Файл опубликован: 5 сен 1999
Pin16
Package TypeJ
Industry STD TermCDIP
JEDEC CodeR-GDIP-T
Package QTY1
МаркировкаUC2834J
Width (мм)6.92
Length (мм)19.56
Thickness (мм)4.57
Pitch (мм)2.54
Max Height (мм)5.08
RoHSSee ti.com
  • Versatile UC1834 Optimizes Linear Regulator Efficiency
    PDF, 463 Кб, Файл опубликован: 5 сен 1999
    Linear voltage regulators have long been an important resource to power supply designers. Three-terminal fixed-voltage linear regulators find extensive use as spot regulators and as post-regulation stages fed by switched-mode supplies. However while inexpensive and simple to use these devices have several performance limitations. They are inefficient power converters they lack versatility an
Серия: UC2834M (1)
  • UC2834J
  • Semiconductors > Space & High Reliability > Power Management Products > Linear Regulators (LDO)
На английском языке: Datasheet Texas Instruments UC2834J
