Datasheet Texas Instruments TPS54974PWPR — Даташит
СерияTPS54974
МодельTPS54974PWPR
Split Rail (3.3V, 2.5V) Input, 9A Synchronous Step-Down SWIFTв„ў ConverterВ  28-HTSSOP -40 to 85
Pin28
Package TypePWP
Industry STD TermHTSSOP
Width (мм)4.4
Length (мм)9.7
Thickness (мм)1
Max Height (мм)1.2
RoHSНе совместим
  • Evaluation Modules & Boards: XILINXPWR-082
    XILINXPWR-082 Power Management Evaluation Module for Xilinx FPGAs
  • Thermal Performance of SWIFT(TM) DC/DC Converters in the 28-Pin HTSSOP Package
    PDF, 267 Кб, Файл опубликован: 4 фев 2005
    The thermal management of printed-circuit boards is complex, but must be well understood to achieve optimum performance and reliability. SWIFT(TM) dc/dc converters in the 28-pin HTSSOP package rely on an exposed lead frame die pad [PowerPAD(TM)] on the bottom of the package to provide an extremely low thermal resistance from junction to case. The thermal performance of the 6-, 9-, and 14-A SWIFT d
Серия: TPS54974 (2)
На английском языке: Datasheet Texas Instruments TPS54974PWPR
