Datasheet Texas Instruments LM723CH — Даташит
СерияLM723C-MIL
МодельLM723CH
Линейный регулятор с регулируемым выходом 150 мА / LDO 10-TO-100 от 0 до 70
LM723/LM723C Voltage Regulator datasheet
PDF, 985 Кб, Версия: C, Файл опубликован: 9 апр 2013
Pin1010
Package TypeLMELME
Industry STD TermTO-CANTO-CAN
JEDEC CodeO-MBCY-WO-MBCY-W
Package QTY500500
МаркировкаLM723CHLM723CH
Width (мм)8.968.96
Length (мм)8.968.96
Thickness (мм)4.44.4
Pitch (мм)2.922.92
Max Height (мм)5.725.72
RoHSSee ti.com
  • AN-1148 Linear Regulators: Theory of Operation and Compensation (Rev. B)
    PDF, 300 Кб, Версия: B, Файл опубликован: 6 май 2013
    This application note discusses the operation and compensation of linear regulators.
  • Digital Designer's Guide to Linear Voltage Regulators & Thermal Mgmt (LDO) (Rev. A)
    PDF, 509 Кб, Версия: A, Файл опубликован: 4 июн 2008
  • Understanding the Terms and Definitions of LDO Voltage Regulators
    PDF, 197 Кб, Файл опубликован: 21 окт 1999
    This report provides an understanding of the terms and definitions of low dropout (LDO) voltage regulators and describes fundamental concepts including dropout voltage quiescent current standby current efficiency transient response line/load regulation power supply rejection output noise voltage accuracy and power dissipation. Each section includes an example to increase the understandab
  • Packaging Limits Range of Linear Regulators
    PDF, 75 Кб, Файл опубликован: 8 май 2010
    The power limitations of the physical packaging for a linear regulator device can limit the total output current or the input-to-output voltage differential. This inherent limitation is not always apparent from the product data sheet and must be evaluated during the design phase. This application note shows how the package can limit the operating envelope of a linear regulator.
Серия: LM723C-MIL (2)
На английском языке: Datasheet Texas Instruments LM723CH
Публикации по теме
