Datasheet Texas Instruments BQ2005STRG4 — Даташит
| Серия | BQ2005 |
| Модель | BQ2005STRG4 |
Импульсное зарядное устройство NiCd/NiMH аккумуляторов для последовательной зарядки двух аккумуляторных блоков 20-SOIC от -20 до 70
Fast-Charge IC for Dual-Battery Packs datasheet
PDF, 657 Кб, Версия: A, Файл опубликован: 25 июл 2000
Купить BQ2005STRG4 на РадиоЛоцман.Цены — от 169 до 318 ₽12 предложений от 12 поставщиков Микросхема Чип управления батареи, Fast Charge Management NiCD/NiMH 2000mA 20Pin SOIC T/R | |||
| BQ2005STRG4 Texas Instruments | 211 ₽ | ||
| BQ2005STRG4 Texas Instruments | 266 ₽ | ||
| BQ2005STRG4 Texas Instruments | 318 ₽ | ||
| BQ2005STRG4 Texas Instruments | по запросу | ||
| Pin | 20 | 20 |
| Package Type | DW | DW |
| Industry STD Term | SOIC | SOIC |
| JEDEC Code | R-PDSO-G | R-PDSO-G |
| Package QTY | 2000 | 2000 |
| Carrier | LARGE T&R | LARGE T&R |
| Маркировка | -D | 2005S |
| Width (мм) | 7.5 | 7.5 |
| Length (мм) | 12.8 | 12.8 |
| Thickness (мм) | 2.35 | 2.35 |
| Pitch (мм) | 1.27 | 1.27 |
| Max Height (мм) | 2.65 | 2.65 |
| Absolute Vin (safety rating)(Max)( | 7 В |
| Battery Charge Voltage(Max) | 20 В |
| Cell Chemistry | NiCd,NiMH |
| Charge Current(Max) | 2 A |
| Control Interface | Standalone (RC-Settable) |
| Control Topology | Switch-Mode Buck |
| Number of Series Cells | 1,2,3,4 |
| Operating Vin(Max) | 5.5 В |
| Operating Vin(Min) | 4.5 В |
| Package Group | SOIC |
| Package Size: mm2:W x L | 20SOIC: 132 mm2: 10.3 x 12.8(SOIC) PKG |
| Special Features | Temp Monitoring (Thermistor Pin) |
| USB Feature | N/A |
- U-507 Using the bq2005 to Control Fast ChargePDF, 241 Кб, Файл опубликован: 5 сен 1999
The bq2005 is a fast-charge IC that provides comprehensive fast-charge control functions and high-speed switching power-control circuitry on a monolithic CMOS device. The bq2005 offers sequential charge management in dual-battery-pack applications. This application note describes the use of the bq2005 to control a current source to fast-charge NiCd or NiMH batteries. The bq2005 can also serve as t - Battery Charger Termination Issues With System Load Applied Across Battery (Rev. A)PDF, 151 Кб, Версия: A, Файл опубликован: 2 окт 2006
Battery Charger Termination Issues With System Load Applied Across Battery While Charging
- Semiconductors > Power Management > Battery Management Products > Battery Charger IC
