Datasheet Texas Instruments SN74LVT125DR — Даташит
СерияSN74LVT125
МодельSN74LVT125DR
Буферы с четырьмя шинами ABT, 3,3 В, с выходами с 3 состояниями, 14-SOIC, от -40 до 85
SN74LVT125 datasheet
PDF, 673 Кб, Версия: F, Файл опубликован: 13 окт 2003
40 предложений от 21 поставщиков
Интегральные микросхемы Логические микросхемы - Буферы, Приемники, Приемопередатчики
SN74LVT125DR
от 10 ₽
SN74LVT125DR
70 ₽
SN74LVT125DR
SUV System
SN74LVT125DR
Pin14
Package TypeD
Package QTY2500
МаркировкаLVT125
Width (мм)3.91
Length (мм)8.65
Thickness (мм)1.58
Max Height (мм)1.75
Bits4
F @ Nom Voltage(Max)100 Mhz
ICC @ Nom Voltage(Max)0.007 мА
Output Drive (IOL/IOH)(Max)-32/64 мА
Schmitt TriggerNo
Technology FamilyLVT
VCC(Max)3.6 В
VCC(Min)2.7 В
Voltage(Nom)3.3 В
tpd @ Nom Voltage(Max)4 нс
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
На английском языке: Datasheet Texas Instruments SN74LVT125DR
