Datasheet Texas Instruments TLC5924DAPR — Даташит
| Серия | TLC5924 |
| Модель | TLC5924DAPR |
16-канальный светодиодный драйвер с коррекцией точек и полевым транзистором предварительной зарядки 32-HTSSOP от -40 до 85
16-Channel LED Driver With DOT Correction and Pre-Charge FET datasheet
PDF, 1.2 Мб, Файл опубликован: 20 июн 2006
Купить TLC5924DAPR на РадиоЛоцман.Цены — от 47 до 408 ₽17 предложений от 14 поставщиков IC LED DRIVER LIN 80MA 32HTSSOP. LED Driver IC 16 Output Linear Shift Register Dimming 80mA 32-HTSSOP. PMIC - LED Drivers... | |||
| TLC5924DAPR Texas Instruments | 47 ₽ | ||
| TLC5924DAPR Texas Instruments | 175 ₽ | ||
| TLC5924DAPR Texas Instruments | 289 ₽ | ||
| TLC5924DAPR Texas Instruments | 292 ₽ | ||
| Pin | 32 |
| Package Type | DAP |
| Industry STD Term | HTSSOP |
| JEDEC Code | R-PDSO-G |
| Package QTY | 2000 |
| Carrier | LARGE T&R |
| Маркировка | TLC5924 |
| Width (мм) | 6.2 |
| Length (мм) | 11 |
| Thickness (мм) | 1.15 |
| Pitch (мм) | .65 |
| Max Height (мм) | 1.2 |
| Mechanical Data | Скачать |
| Analog Dimming Steps | 128 |
| Ch to Ch Accuracy(Typ) | 1 +/- % |
| Data Transfer Rate(Typ) | 30 МГц |
| Package Group | HTSSOP |
| Package Size: mm2:W x L | 32HTSSOP: 89 mm2: 8.1 x 11(HTSSOP) PKG |
| Rating | Catalog |
| Special Features | Error Flag,Fault Detection,LED Open Detection,Power Good |
- LED Driver--Paralleled Outputs Provide High Current OutputsPDF, 957 Кб, Файл опубликован: 25 сен 2006
This application report describes how to use the TLC5922, TLC5923, and TLC5924 to drive high-current LEDs. These ICs are designed to provide 16 individually controllable constant-current sinks. However, the 16 outputs can be connected in parallel to increase the current drive capability. Paralleling the outputs of these ICs allows the TLC5922, TLC5923, and TLC5924 to drive high-power LEDs such as
Серия: TLC5924 (7)
- Semiconductors > Power Management > LED Driver > Signage & Large Display LED Driver
