Datasheet Texas Instruments SN74LVCH244ADGVR — Даташит
СерияSN74LVCH244A
МодельSN74LVCH244ADGVR
Восьмеричный буфер/драйвер с выходами с 3 состояниями 20-TVSOP от -40 до 85
SN54LVCH244A, SN74LVCH244A datasheet
PDF, 1.6 Мб, Версия: O, Файл опубликован: 5 фев 2007
Pin20
Package TypeDGV
Industry STD TermTVSOP
Package QTY2000
МаркировкаLCH244A
Width (мм)4.4
Length (мм)5
Thickness (мм)1.05
Pitch (мм).4
Max Height (мм)1.2
Bits8
F @ Nom Voltage(Max)100 Mhz
ICC @ Nom Voltage(Max)0.01 мА
Output Drive (IOL/IOH)(Max)-24/24 мА
Package GroupTVSOP
Package Size: mm2:W x L20TVSOP: 32 mm2: 6.4 x 5(TVSOP) PKG
Schmitt TriggerNo
Technology FamilyLVC
VCC(Max)3.6 В
VCC(Min)1.65 В
Voltage(Nom)1.8,2.5,2.7,3.3 В
tpd @ Nom Voltage(Max)6.9,5.9 нс
  • Bus-Hold Circuit
    PDF, 418 Кб, Файл опубликован: 5 фев 2001
    When designing systems that include CMOS devices, designers must pay special attention to the operating condition in which all of the bus drivers are in an inactive, high-impedance condition (3-state). Unless special measures are taken, this condition can lead to undefined levels and, thus, to a significant increase in the device?s power dissipation. In extreme cases, this leads to oscillation of
На английском языке: Datasheet Texas Instruments SN74LVCH244ADGVR
