Datasheet Texas Instruments LM392M — Даташит
СерияLM392-N
МодельLM392M
Операционный усилитель малой мощности/компаратор напряжения 8-SOIC 0–70
LM392 Low Power Operational Amplifier/Voltage Comparator datasheet
PDF, 860 Кб, Версия: D, Файл опубликован: 21 мар 2013
Pin88
Package TypeDD
Industry STD TermSOICSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY9595
CarrierTUBETUBE
МаркировкаMLM392
Width (мм)3.913.91
Length (мм)4.94.9
Thickness (мм)1.581.58
Pitch (мм)1.271.27
Max Height (мм)1.751.75
Рекомендуемая замена
ReplacementLM392M/NOPB
Replacement CodeS
Input Bias Current (+/-)(Max)250 нА
Iq per channel(Max)1 мА
Количество каналов2
Тип выходаOpen Collector
Propagation Delay Time1.5 uS
Rail-to-RailOut
Special FeaturesWith Op Amp
VICR(Max)30 В
Vos (Offset Voltage @ 25C)(Max)5 мВ
Vs(Max)32 В
Vs(Min)3 В
RoHSSee ti.com
  • CMOS ADC Interfaces Easily with many Microprocessors (Rev. B)
    PDF, 183 Кб, Версия: B, Файл опубликован: 30 апр 2013
    To help meet the rising demand for easier interfacing between analog-to-digital converters and microprocessors, the complementary MOS, 8-bit ADC0801-05 has been designed to accommodate almost all of today's popular microprocessors. It requires only a single 5 V supply and is low power to boot. With a span accommodation down to 180 mV, this 8-bit unit can also replace a 12-bit analog-to-digital dev
  • AN-286 Applications of the LM392 Comparator Op Amp IC (Rev. B)
    PDF, 462 Кб, Версия: B, Файл опубликован: 26 апр 2013
    This application note discusses the uses of the LM339 quad comparator and the LM324 op amp areamong the most widely used linear ICs today. The combination of low cost, single or dual supply operationand ease of use has contributed to the wide range of applications for these devices.
  • Semiconductors > Amplifiers > Comparators
На английском языке: Datasheet Texas Instruments LM392M
Публикации по теме
