Datasheet Texas Instruments LM3406MH/NOPB — Даташит
СерияLM3406
МодельLM3406MH/NOPB
Понижающий стабилизатор постоянного тока 1,5 А для управления мощными светодиодами 14-HTSSOP от -40 до 125
LM3406/06HV 1.5A Constant Current Buck Regulator for Driving High Power LEDs datasheet
PDF, 1.2 Мб, Версия: E, Файл опубликован: 17 фев 2014
Pin1414
Package TypePWPPWP
Industry STD TermHTSSOPHTSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY9494
CarrierTUBETUBE
МаркировкаLM3406MH
Width (мм)4.44.4
Length (мм)55
Thickness (мм)11
Pitch (мм).65.65
Max Height (мм)1.21.2
Dimming Method2-Wire,PWM
Входное напряжениеDC/DC Type
Iout(Max)1.5 A
Iq(Typ)1.2 мА
Package GroupHTSSOP
Package Size: mm2:W x L14HTSSOP: 32 mm2: 6.4 x 5(HTSSOP) PKG
Power Factor CorrectionN/A Min
Regulated Outputs1
Special FeaturesAdjustable Switch Frequency,Enable/Shutdown,Integrated Switch,Precision Dimming Control,Thermal Shutdown
Switching Frequency(Max)1000 kHz
Switching Frequency(Min)20 kHz
TopologyBuck
ТипConverter,Inductive
Vin(Max)42 В
Vin(Min)6 В
Vout(Max)40 В
Vout(Min)0.2 В
Vref0.2 В
  • Evaluation Modules & Boards: LM3406MHEVAL
    LM3406 - 1.5A Constant Current Buck Regulator Evaluation Board for Driving High Power LEDs
  • Dimming Techniques for Switched-Mode LED Drivers
    PDF, 425 Кб, Файл опубликован: 30 июл 2009
  • AN-1982 Small, Wide Input Voltage Range LM2842 Keeps LEDs Cool (Rev. A)
    PDF, 60 Кб, Версия: A, Файл опубликован: 23 апр 2013
    The world seems to be poised to make the leap to LED lighting. Incandescent has been deemed tooinefficient, which it is, and fluorescent lighting often does not achieve the lifetime it claims. Fluorescentalso has another set of baggage, dangerous chemicals. So the logical choice that most people believe cantake the crown is high brightness (HB) LEDs. HBLEDs are becoming more attractive as th
  • AN-1656 Design Challenges of Switching LED Drivers (Rev. A)
    PDF, 171 Кб, Версия: A, Файл опубликован: 3 май 2013
    Using a switching regulator as an LED driver requires the designer to convert a voltage regulator into acurrent regulator. Beyond the challenge of changing the feedback system to control current, the LEDsthemselves present a load characteristic that is much different than the digital devices and other loads thatrequire constant voltage. The LED WEBENCHВ® online design environment predicts and
Серия: LM3406 (3)
  • Semiconductors > Power Management > LED Driver > Illumination & General Lighting LED Driver
На английском языке: Datasheet Texas Instruments LM3406MH/NOPB
