Datasheet Texas Instruments TPS5102IDBT — Даташит
СерияTPS5102
МодельTPS5102IDBT
Синхронный понижающий контроллер с двумя выходами и широким диапазоном входного напряжения 30-TSSOP от -40 до 85
Dual High Efficiency Controller For Notebook PC Power datasheet
PDF, 1.2 Мб, Файл опубликован: 28 сен 1999
Pin30
Package TypeDBT
Industry STD TermTSSOP
Package QTY60
МаркировкаPU5102
Width (мм)4.4
Length (мм)7.8
Thickness (мм)1
Pitch (мм).5
Max Height (мм)1.2
  • Power Control Design Key To Realizing Infiniband Benefits
    PDF, 49 Кб, Файл опубликован: 1 ноя 2001
    As a new interface, InfiniBand (sm) presents a lot of expansion opportunities. However, in most new specifications, the true implementation details for the power requirements are either limited or lack clear associations between truly related parameters. Not only do you need to know the power requirements for the module and the system, you need to know how to manage that power in a hot-swappable
  • Voltage Regulator Solutions for Xilinx Virtex E Dual Voltage FPGAs
    PDF, 77 Кб, Файл опубликован: 13 июн 2000
    This application report serves as a reference for engineers designing with Xilinix 2.5-V and 1.8-V Virtex multivoltage FPGA products. It provides basic information on the issues facing engineers not experienced with multivoltage type products.
  • Power Supply Sequencing Solutions for Dual Supply Voltage DSPs (Rev. A)
    PDF, 104 Кб, Версия: A, Файл опубликован: 5 июл 2000
    This application report describes power-supply sequencing recommendations and techniques applicable to dual supply voltage DSPs in TI's TMS320C2000 TMS320C5000 and TMS320C6000 families. These techniques take advantage of the reset power good enable and soft-start features available on TI Power Management Products including low drop out regulators switching power supply controllers supply vol
Серия: TPS5102 (3)
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Down (Buck) > Buck Controller (External Switch)
На английском языке: Datasheet Texas Instruments TPS5102IDBT
