Datasheet Texas Instruments UC1856L — Даташит
СерияUC1856
МодельUC1856L
Improved Current Mode PWM Controller datasheet
PDF, 3.3 Мб, Версия: A, Файл опубликован: 7 окт 2010
Pin28
Package TypeL
Рекомендуемая замена
ReplacementUC1856L20
Replacement CodeP
Control MethodCurrent
Duty Cycle(Max)(%)50
Frequency(Max)(kHz)1000
Operating Temperature Range(C)-55 to 125
Package GroupCDIP
LCCC
Package Size: mm2:W x L (PKG)See datasheet (CDIP)
RatingMilitary
Special FeaturesError Amplifier
Synchronization Pin
Soft Start
Multi-topology
TopologyBoost
Flyback
Forward
Full-Bridge
Half-Bridge
Push-Pull
UVLO Thresholds On/Off(V)7.7/7
Vin(Max)(V)40
Vin(Min)(V)8
RoHSНе совместим
  • DN-45 UC3846 UC3856 and UCC3806 Push Pull PWM Current Mode Control ICs
    PDF, 27 Кб, Файл опубликован: 5 сен 1999
    The UC3856 is a pin-for-pin-compatible high-performance bipolar version of the industry standard UC3846. It can replace the UC3846 with few circuit modifications and it features increased speed higher gate-drive current and reduced propagation delays. The UCC3806 is a BiCMOS pin-for-pin compatible ultra-low-power version ideal for battery low-power and high-speed applications. The UCC3806
  • DN-62 Switching Power Supply Topology Voltage Mode vs. Current Mode
    PDF, 66 Кб, Файл опубликован: 5 сен 1999
    This design note explains the differences between voltage-mode and current-mode switching power supply topologies. It includes a circuit diagram for each mode and suggests criteria for choosing which mode to use.
  • Semiconductors > Space & High Reliability > Power Management Products > Offline and Isolated DC/DC Controller and Converter
На английском языке: Datasheet Texas Instruments UC1856L
