Datasheet Texas Instruments OPA657N/250G4 — Даташит
СерияOPA657
МодельOPA657N/250G4
1,6 ГГц, малошумящий операционный усилитель с входом на полевом транзисторе 5-SOT-23 от -40 до 85
OPA657 1.6-GHz, Low-Noise, FET-Input Operational Amplifier datasheet
PDF, 1.3 Мб, Версия: F, Файл опубликован: 31 авг 2015
Pin5
Package TypeDBV
Industry STD TermSOT-23
Package QTY250
CarrierSMALL T&R
МаркировкаA57
Width (мм)1.6
Length (мм)2.9
Thickness (мм)1.2
Pitch (мм).95
Max Height (мм)1.45
2nd Harmonic74 dBc
3rd Harmonic106 dBc
@ MHz5
Acl, min spec gain7 V/V
Additional FeaturesDecompensated
АрхитектураFET,Voltage FB
BW @ Acl350 МГц
CMRR(Min)83 дБ
CMRR(Typ)89 дБ
GBW(Typ)1600 МГц
Input Bias Current(Max)20 pA
Iq per channel(Max)16 мА
Iq per channel(Typ)14 мА
Количество каналов1
Offset Drift(Typ)2 uV/C
Output Current(Typ)70 мА
Package GroupSOT-23
Package Size: mm2:W x L5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG
Rail-to-RailNo
Slew Rate(Typ)700 V/us
Total Supply Voltage(Max)12 +5V=5, +/-5V=10
Total Supply Voltage(Min)8 +5V=5, +/-5V=10
Vn at 1kHz(Typ)7 нВ/rtГц
Vn at Flatband(Typ)4.8 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)1.8 мВ
  • Evaluation Modules & Boards: DEM-OPA-SO-1A
    DEM-OPA-SO-1A Unpopulated PCB Compatible w/High Speed Wide Bandwidth Op Amps in 8-lead SOIC (D) Pkg
  • Evaluation Modules & Boards: DEM-OPA-SOT-1A
    Unpopulated PCB Compatible w/High Speed, Wide Bandwidth Op Amps in SOT(DBV) Pkg
  • Measuring Board Parasitics in High-Speed Analog Design
    PDF, 134 Кб, Файл опубликован: 7 июл 2003
    Successful circuit designs using high-speed amplifiers can depend upon understanding and identifying parasitic PCB components. Simulating a design while including PCB parasitics can protect against unpleasant production surprises. This application report discusses an easy method for measuring parasitic components in a prototype or final PC board design by using a standard oscilloscope and low freq
  • Voltage Feedback vs. Current Feedback Op Amps
    PDF, 93 Кб, Файл опубликован: 30 ноя 1998
    This application report contrasts and compares the characteristics and capabilities of voltage and current feedback operational amplifiers. The report also points out the many similarities between the two versions.
  • Designing for low distortion with high-speed op amps
    PDF, 277 Кб, Файл опубликован: 2 мар 2005
  • Transimpedance Considerations for High-Speed Operational Amplifiers
    PDF, 193 Кб, Файл опубликован: 22 ноя 2009
    Designing high-resolution detection circuits using photodiodes presents considerable challenges because bandwidth, gain, and input-referred noise are coupled together. This application note reviews the basic issues of transimpedance design, provides a set of detailed design equations, explains those equations, and develops an approach to easily compare potential solutions.
  • Using a decompensated op amp for improved performance
    PDF, 352 Кб, Файл опубликован: 11 мар 2005
  • Transimpedance Amplifiers (TIA): Choosing the Best Amplifier for the job (Rev. A)
    PDF, 153 Кб, Версия: A, Файл опубликован: 16 май 2017
    This application note is intended as a guide for the designer looking to amplify the small signal from a photodiode or avalanche diode so that it would be large enough for further processing (e.g. data acquisition) or to trigger some other event in a system. The challenge in doing so, as always, is to not degrade the signal such that it becomes indistinguishable from random noi
На английском языке: Datasheet Texas Instruments OPA657N/250G4
