Datasheet Texas Instruments ADS7871IDBR — Даташит
СерияADS7871
МодельADS7871IDBR
14-битный DAS 48KSPS с АЦП, мультиплексором, PGA и внутренним опорным сигналом 28-SSOP от -40 до 85
ADS7871: 14-Bit A/D Converter, MUX, PGA & Internal Reference DAQ System datasheet
PDF, 951 Кб, Версия: C, Файл опубликован: 4 окт 2004
Pin28
Package TypeDB
Industry STD TermSSOP
Package QTY1000
МаркировкаADS7871
Width (мм)5.3
Length (мм)10.2
Thickness (мм)1.95
Max Height (мм)2
# Input Channels8
Analog Voltage AVDD(Max)5.5 В
Analog Voltage AVDD(Min)2.7 В
АрхитектураSAR
Digital Supply(Max)5.5 В
Digital Supply(Min)2.7 В
INL(Max)4 +/-LSB
Input Range(Max)5.5 В
Тип входаDifferential,Single-Ended
Integrated FeaturesOscillator,PGA
InterfaceSPI
Package GroupSSOP
Package Size: mm2:W x L28SSOP: 80 mm2: 7.8 x 10.2(SSOP) PKG
Power Consumption(Typ)8.5 mW
Reference ModeExt,Int
Разрешение14 Bits
SINADN/A дБ
Sample Rate (max)48kSPS SPS
Sample Rate(Max)0.048 MSPS
THD(Typ)N/A дБ
  • Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)
    PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
    This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
Серия: ADS7871 (4)
На английском языке: Datasheet Texas Instruments ADS7871IDBR
