Datasheet Texas Instruments BUF600AU — Даташит
СерияBUF600
МодельBUF600AU
Высокоскоростной буферный усилитель 8-SOIC
Package TypeD
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
Рекомендуемая замена
ReplacementOPA692ID
Replacement CodeP
RoHSНе совместим
  • Macromodels for RF Op Amps Are a Powerful Design Tool
    PDF, 68 Кб, Файл опубликован: 2 окт 2000
    The macromodel for the Diamond Transistor OPA660 gives an example of the structure and performance of these new Spice models.
  • The MPC100 Analog Multiplexer Improves RF Signal Distribution
    PDF, 131 Кб, Файл опубликован: 27 сен 2000
    The new 4 to 1 video multiplexer MPC100 opens the door to high-speed signal distribution without the headaches. This component contains four wideband open-loop amplifiers connected together internally
  • Designing Active Filters with the Diamond Transistor OPA660
    PDF, 114 Кб, Файл опубликован: 27 сен 2000
    Signal frequency bandwidth limitation, fast pulse shaping, separation between telecommunications signals, and suppression of unwanted carrier and disturbance frequencies are among the most important jobs of filter circuits. While active filters with operational amplifiers and switched capacitor filters are used for lower frequency applications, passive filter versions dominate the application spec
Серия: BUF600 (2)
На английском языке: Datasheet Texas Instruments BUF600AU
