Datasheet Texas Instruments 5962-9051401MSA — Даташит
| Серия | SN54BCT245 |
| Модель | 5962-9051401MSA |
Восьмеричные шинные трансиверы с выходами с 3 состояниями 20-CFP от -55 до 125
Octal Bus Transceivers With 3-State Outputs datasheet
PDF, 1.4 Мб, Версия: H, Файл опубликован: 3 май 2002
Купить 5962-9051401MSA на РадиоЛоцман.Цены — от 3 230 до 3 934 ₽5 предложений от 5 поставщиков Микросхема Логический чип, Bus XCVR Single 8CH 3-ST 20Pin CFPAK Tube | |||
| 5962-9051401MSA Texas Instruments | 3 934 ₽ | ||
| 5962-9051401MSA Texas Instruments | по запросу | ||
| Pin | 20 |
| Package Type | W |
| Industry STD Term | CFP |
| JEDEC Code | R-GDFP-F |
| Package QTY | 1 |
| Carrier | TUBE |
| Width (мм) | 6.92 |
| Length (мм) | 13.09 |
| Thickness (мм) | 1.84 |
| Pitch (мм) | 1.27 |
| Max Height (мм) | 2.45 |
| Mechanical Data | Скачать |
| Bits | 8 |
| Рабочий диапазон температур | от -55 до 125 C |
| Package Group | CFP |
| Package Size: mm2:W x L | See datasheet (CFP) PKG |
| Rating | Military |
| Schmitt Trigger | No |
| Technology Family | BCT |
| VCC(Max) | 5.5 В |
| VCC(Min) | 4.5 В |
| RoHS | See ti.com |
- Bus-Interface Devices With Output-Damping Resistors Or Reduced-Drive Outputs (Rev. A)PDF, 105 Кб, Версия: A, Файл опубликован: 1 авг 1997
The spectrum of bus-interface devices with damping resistors or balanced/light output drive currently offered by various logic vendors is confusing at best. Inconsistencies in naming conventions and methods used for implementation make it difficult to identify the best solution for a given application. This report attempts to clarify the issue by looking at several vendors? approaches and discussi - Semiconductor Packing Material Electrostatic Discharge (ESD) ProtectionPDF, 337 Кб, Файл опубликован: 8 июл 2004
Forty-eight-pin TSSOP components that were packaged using Texas Instruments (TI) standard packing methodology were subjected to electrical discharges between 0.5 and 20 kV as generated by an IEC ESD simulator to determine the level of ISD protection provided by the packing materials. The testing included trays tape and reel and magazines. Additional units were subjected to the same discharge - Introduction to LogicPDF, 93 Кб, Файл опубликован: 30 апр 2015
- Understanding and Interpreting Standard-Logic Data Sheets (Rev. C)PDF, 614 Кб, Версия: C, Файл опубликован: 2 дек 2015
- Live InsertionPDF, 150 Кб, Файл опубликован: 1 окт 1996
Many applications require the ability to exchange modules in electronic systems without removing the supply voltage from the module (live insertion). For example an electronic telephone exchange must always remain operational even during module maintenance and repair. To avoid damaging components additional circuitry modifications are necessary. This document describes in detail the phenomena tha - Input and Output Characteristics of Digital Integrated CircuitsPDF, 1.7 Мб, Файл опубликован: 1 окт 1996
This report contains a comprehensive collection of the input and output characteristic curves of typical integrated circuits from various logic families. These curves go beyond the information given in data sheets by providing additional details regarding the characteristics of the components. This knowledge is particularly useful when for example a decision must be made as to which circuit shou - Designing With Logic (Rev. C)PDF, 186 Кб, Версия: C, Файл опубликован: 1 июн 1997
Data sheets which usually give information on device behavior only under recommended operating conditions may only partially answer engineering questions that arise during the development of systems using logic devices. However information is frequently needed regarding the behavior of the device outside the conditions in the data sheet. Such questions might be:?How does a bus driver behave w - Implications of Slow or Floating CMOS Inputs (Rev. D)PDF, 260 Кб, Версия: D, Файл опубликован: 23 июн 2016
- TI IBIS File Creation Validation and Distribution ProcessesPDF, 380 Кб, Файл опубликован: 29 авг 2002
Серия: SN54BCT245 (6)
- 5962-9051401M2A 5962-9051401MRA 5962-9051401MSA SNJ54BCT245FK SNJ54BCT245J SNJ54BCT245W
- Semiconductors > Space & High Reliability > Logic Products > Buffers/Drivers/Transceivers > Transceiver
59629051401MSA, 5962 9051401MSA
