Datasheet Texas Instruments DAC8831ICDG4 — Даташит
СерияDAC8831
МодельDAC8831ICDG4
16-битный цифро-аналоговый преобразователь сверхмалого энергопотребления с выходным напряжением 14-SOIC от -40 до 85
16-Bit, Ultra-Low Power, Voltage Output Digital-to-Analog Converters datasheet
PDF, 1.3 Мб, Версия: D, Файл опубликован: 14 сен 2007
Pin14
Package TypeD
Package QTY50
МаркировкаDAC8831I
Width (мм)3.91
Length (мм)8.65
Thickness (мм)1.58
Max Height (мм)1.75
Code to Code Glitch(Typ)35 nV-sec
DAC ArchitectureR-2R
DAC Channels1
Gain Error(Max)0.01 %FSR
INL(Max)1 +/-LSB
InterfaceSPI
Offset Error(Max)N/A %
Output Range Max.5.5 mA/V
Output Range Min.-5.5 mA/V
Тип выходаUnbuffered Voltage
Power Consumption(Typ)0.015 mW
Reference: TypeExt
Разрешение16 Bits
Sample / Update Rate2 MSPS
Время установления1 µs
Special FeaturesN/A
Zero Code Error(Typ)1 мВ
  • Evaluation Modules & Boards: DAC8831EVM
    DAC8831EVM Evaluation Module
  • Evaluation Modules & Boards: TSW7001EVM
    TSW7001 Voltage-Controlled Amplifier Demonstration Kit
  • Interfacing the DAC8831EVM to TMS470 Processors
    PDF, 54 Кб, Файл опубликован: 14 апр 2005
    This application report presents a method for interfacing the DAC8831 - a single-channel, low-power, 16-bit serial digital-to-analog converter - to the TMS470R1A256 processor using the TMS-FET470A256 Kickstart Development Kit from IAR Systems. The software developed creates a 256-point sine table, and then continuously writes values from the sine table to the DAC8831. To reduce development time, t
  • Interfacing the DAC8831EVM to TMS320C5x Processors
    PDF, 59 Кб, Файл опубликован: 14 апр 2005
    This application report presents a method for interfacing the DAC8831 - a single-channel, low-power, 16-bit serial digital-to-analog converter - to the TMS320C5x series DSKs using the McBSP0 and/or McBSP1 and the 5-6K Interface Board. The software developed creates a 256-point sine table and then continuously writes values from the sine table to the DAC8831. To reduce development time, the source
  • Interfacing the DAC8831EVM to TMS320C6x Processors
    PDF, 60 Кб, Файл опубликован: 14 апр 2005
    This application report presents a method for interfacing the DAC8831 - a single-channel, low-power, 16-bit serial digital-to-analog converter - to the TMS320C6x series DSKs using McBSP1 and the 5-6K Interface Board. The software developed creates a 256-point sine table, and then continuously writes values from the sine table to the DAC8831. To reduce development time, the source code for this ap
  • Interfacing the DAC8831EVM to MSP430 Processors
    This application report presents a method for interfacing the DAC8831 - a single-channel, low-power, 16-bit serial digital-to-analog converter - to the MSP430F449 microcontroller using the HPA449 from SoftBaugh. The software developed creates a 256-point sine table and then continuously writes values from the sine table to the DAC8831. To reduce development time, the source code for this applicati
На английском языке: Datasheet Texas Instruments DAC8831ICDG4
