Datasheet Texas Instruments MSP430FR5986IPM — Даташит
| Серия | MSP430FR5986 |
| Модель | MSP430FR5986IPM |
MSP430FR5986 Микроконтроллер ULP, 16 МГц, 48 КБ FRAM, 2 КБ SRAM, 48 входов/выходов, ADC12, Scan IF, AES 64-LQFP от -40 до 85
MSP430FR698x(1), MSP430FR598x(1) Mixed-Signal Microcontrollers datasheet
PDF, 2.7 Мб, Версия: C, Файл опубликован: 9 мар 2017
Купить MSP430FR5986IPM на РадиоЛоцман.Цены — от 298 до 765 ₽11 предложений от 11 поставщиков IC MCU 16BIT 48KB FRAM 64LQFP. CPUXV2 MSP430TM FRAM Microcontroller IC 16-Bit 16MHz 48KB (48K x 8) FRAM 64-LQFP (10x10).... | |||
| MSP430FR5986IPM Texas Instruments | 298 ₽ | ||
| MSP430FR5986IPM Texas Instruments | 538 ₽ | ||
| MSP430FR5986IPM Texas Instruments | 705 ₽ | ||
| MSP430FR5986IPM Texas Instruments | 765 ₽ | ||
| Pin | 64 |
| Package Type | PM |
| Industry STD Term | LQFP |
| JEDEC Code | S-PQFP-G |
| Package QTY | 160 |
| Carrier | JEDEC TRAY (10+1) |
| Маркировка | FR5986 |
| Width (мм) | 10 |
| Length (мм) | 10 |
| Thickness (мм) | 1.4 |
| Pitch (мм) | .5 |
| Max Height (мм) | 1.6 |
| Mechanical Data | Скачать |
| ADC | ADC12 - 12ch |
| AES | AES256 |
| Active Power | 101.25 uA/MHz |
| Additional Features | Real-Time Clock,Watchdog,Scan Interface,Temp Sensor,Brown Out Reset,IrDA,IP Protection |
| BSL | UART |
| CPU | MSP430 |
| Comparators | 12 |
| DMA | 3 |
| Featured | fr5 |
| Тактовая частота | 16 МГц |
| GPIO Pins | 48 |
| I2C | 2 |
| Max VCC | 3.6 |
| Min VCC | 1.8 |
| Multiplier | 32x32 |
| Non-volatile Memory | 48 KB |
| Package Group | LQFP |
| Package Size: mm2:W x L | 64LQFP: 144 mm2: 12 x 12(LQFP) PKG |
| RAM | 2 KB |
| Rating | Catalog |
| SPI | 4 |
| Security Enabler | Cryptographic acceleration,Debug security,Physical security,Secure FW and SW update,Software IP protection |
| Special I/O | N/A |
| Standby Power | 0.9 LPM3-uA |
| Timers - 16-bit | 5 |
| UART | 2 |
| Wakeup Time | 7 us |
- Evaluation Modules & Boards: MSP-FET430U100D
100-pin Target Development Board and MSP-FET Programmer Bundle for MSP430FRxx FRAM MCUs
Статус продукта: В производстве (Рекомендуется для новых разработок) - Evaluation Modules & Boards: MSP-TS430PZ100D
MSP-TS430PZ100D- 100-pin Target Development Board for MSP430FRxx FRAM MCUs
Статус продукта: В производстве (Рекомендуется для новых разработок) - Evaluation Modules & Boards: MSP-EXP430FR6989
MSP430FR6989 LaunchPad Development Kit
Статус продукта: В производстве (Рекомендуется для новых разработок) - JTAG Emulators/ Analyzers: ENERGYTRACE
MSP EnergyTrace Technology
- Method to Select the Value of LC Sensor for MSP430 Extended Scan Interface (ESI)PDF, 374 Кб, Файл опубликован: 28 авг 2014
This document describes a method that can be used to select an LC sensor for use with the MSP430в„ў Extended Scan Interface (ESI). - LC Sensor Rotation Detection With MSP430 Extended Scan Interface (ESI)PDF, 2.2 Мб, Файл опубликован: 28 авг 2014
This application report describes the implementation of a flow meter using the Texas Instruments MSP430FR6989 microcontroller with the Extended Scan Interface (ESI) module. This module can provide a contactless sensing approach to detecting a rotating disc. The number of rotations of the disc indicates the volume flow of gas or water and can be used to calculate the fee for the user. This applicat - Adjustment of ESIOSC Oscillator Frequency (Rev. A)PDF, 192 Кб, Версия: A, Файл опубликован: 30 янв 2015
The MSP430FR698x Extended Scan Interface (ESI) uses two clock sources. These clocks are ACLK and a high-frequency clock generated by the ESI oscillator, ESIOSC. ESIOSC is realized as an RC-oscillator and shows a temperature and voltage dependency. However, a hardware-supported measurement of ESIOSC frequency and adjustment by software allows compensating for the frequency drift. This application r - Migrating From MSP430FW42x Scan Interface to MSP430FR6x8x/FR5x8x ESI (Rev. A)PDF, 95 Кб, Версия: A, Файл опубликован: 6 фев 2015
The purpose of this application report is to facilitate the migration of designs based on the MSP430FW42x Scan Interface (SIF) to the MSP430FR5xx/FR6xx Extended Scan Interface (ESI). This document describes the main differences between the two peripheral modules and provides migration solutions covering both software and hardware aspects. - Secure In-Field Firmware Updates for MSP MCUsPDF, 223 Кб, Файл опубликован: 17 ноя 2015
In-field firmware update is a feature that is increasingly used in microcontroller-based applications today and important benefits include service and support to products that are already deployed in the field (for example, being able to correct bugs or add new functionalities). As common as in-field firmware updates are in embedded systems, this feature is also commonly exploited by attackers; if - Random Number Generation Using MSP430FR59xx and MSP430FR69xx MicrocontrollersPDF, 113 Кб, Файл опубликован: 18 янв 2017
Random number generation has a role in a variety of applications, such as cryptography and tamper detection.In digital systems, it becomes difficult to introduce the concept of true randomness as a machine executes code in the sequence it is programed. This introduces the notion of true random number generators (TRNGs) and pseudorandom number generators (PRNGs), also known as deterministic rando - Migrating From MSP430F4xx Family to MSP430FR58xx/FR59xx/FR68xx/FR69xx Family (Rev. B)PDF, 183 Кб, Версия: B, Файл опубликован: 3 ноя 2016
This application report enables easy migration from MSP430F4xx flash-based MCUs to the MSP430FR58xx/59xx/68xx/69xx family of FRAM-based MCUs. The intent is to highlight key differences between the two families. For more information on the use of the MSP430FR58xx/FR59xx/68xx/69xx devices, see the MSP430FR58xx, MSP430FR59xx, MSP430FR68xx, and MSP430FR69xx Family User's Guide. - Getting Started With EEMBC ULPBench on MSP-EXP430FR5969 (Rev. A)PDF, 381 Кб, Версия: A, Файл опубликован: 29 янв 2015
This is a getting started guide for obtaining the ULPMarkв„ў-CP score using the Embedded Microprocessor Benchmark Consortium (EEMBC) ULPBench and EnergyMonitor with the MSP430FR5969 microcontroller (MCU). This document uses the MSP-EXP430FR5969 LaunchPad development kit as the target evaluation module (EVM) for performing the benchmark.MSP430 Advanced Power Optimizations: ULP Advisor SW and EnergyTrace TechnologyPDF, 4.0 Мб, Файл опубликован: 9 июн 2014
MSP430 microcontrollers are designed specifically for ultra-low-power applications. Features such as multiple low-power modes, instant wakeup, intelligent autonomous peripherals, and much more to enable such ultra-low-power capabilities. Texas Instruments provides valuable tools to help the programmer fully use these benefits and optimize power consumption of the target application. This appDesigning With the MSP430FR58xx, FR59xx, FR68xx, and FR69xx ADC (Rev. A)PDF, 137 Кб, Версия: A, Файл опубликован: 30 мар 2016
Designing an application with the analog-to-digital converter (ADC) requires several considerations to optimize for power and performance. This application report discusses the basics of how you would analyze a data sheet and user's guide to design your application. It goes into the fundamentals of how to optimize your design based on the external requirements and available ADC configurations. TheMSP430 FRAM Technology – How To and Best PracticesPDF, 326 Кб, Файл опубликован: 23 июн 2014
FRAM is a non-volatile memory technology that behaves similar to SRAM while enabling a whole host of new applications, but also changing the way firmware should be designed. This application report outlines the how to and best practices of using FRAM technology in MSP430 from an embedded software development perspective. It discusses how to implement a memory layout according to application-specifMSP430 FRAM Quality and Reliability (Rev. A)PDF, 295 Кб, Версия: A, Файл опубликован: 1 май 2014
FRAM is a nonvolatile embedded memory technology and is known for its ability to be ultra-low power while being the most flexible and easy-to-use universal memory solution available today. This application report is intended to give new FRAM users and those migrating from flash-based applications knowledge on how FRAM meets key quality and reliability requirements such as data retention and enduraMigrating from the MSP430F5xx,F6xx Family to the MSP430FR58xx/FR59xx/68xx Family (Rev. D)PDF, 151 Кб, Версия: D, Файл опубликован: 3 ноя 2016
This application report helps enable easy migration from MSP430F5xx and MSP430F6xx flash-based MCUs to the MSP430FR58xx/FR59xx/68xx/69xx FRAM-based MCUs. For the migration guide to MSP430FR57xx, see Migrating From the MSP430F2xx Family to the MSP430FR57xx Family. It covers programming, system, and peripheral considerations when migrating firmware. The intent is to highlight differences between theMigrating from the MSP430F2xx,G2xx Family to the MSP430FR58xx/FR59xx/68xx/69xx (Rev. E)PDF, 179 Кб, Версия: E, Файл опубликован: 3 ноя 2016
This application report enables easy migration from MSP430F2xx flash-based MCUs to the MSP430FR58xx/FR59xx/68xx/69xx family of FRAM-based MCUs. For the migration guide to MSP430FR57xx, see Migrating From the MSP430F2xx Family to the MSP430FR57xx Family. It covers programming, system, and peripheral considerations when migrating firmware. The intent is to highlight key differences between the two fМодельный ряд
Серия: MSP430FR5986 (2)- MSP430FR5986IPM MSP430FR5986IPMR
- Semiconductors > Microcontrollers (MCU) > MSP430 ultra-low-power MCUs > MSP430FRxx FRAM
На английском языке: Datasheet Texas Instruments MSP430FR5986IPM
