Линейка продуктов KEEN SIDE
Datasheet Texas Instruments 5962-9861601QFA — Даташит
СерияSN54AHCT123A
Модель5962-9861601QFA
ДВОЙНЫЕ МОНОСТАБИЛЬНЫЕ МУЛЬТИВИБРАТОРЫ С ПЕРЕЗАПУСКНЫМ ЗАПУСКОМ 16-CFP от -55 до 125
SN54AHCT123A, SN74AHCT123A datasheet
PDF, 931 Кб, Версия: G, Файл опубликован: 2 апр 2003
Pin161616
Package TypeWWW
Industry STD TermCFPCFPCFP
JEDEC CodeR-GDFP-FR-GDFP-FR-GDFP-F
Package QTY111
CarrierTUBETUBETUBE
Маркировка5962-9861601QFSNJ54AHCT123AWA
Width (мм)6.736.736.73
Length (мм)10.310.310.3
Thickness (мм)1.651.651.65
Pitch (мм)1.271.271.27
Max Height (мм)2.032.032.03
Bits2
F @ Nom Voltage(Max)110 Mhz
ICC @ Nom Voltage(Max)0.975 мА
Тип входаTTL
Output Drive (IOL/IOH)(Max)8/-8 мА
Тип выходаCMOS
Package GroupCFP
Package Size: mm2:W x LSee datasheet (CFP) PKG
RatingMilitary
Technology FamilyAHCT
VCC(Max)5.5 В
VCC(Min)4.5 В
Voltage(Nom)5 В
tpd @ Nom Voltage(Max)15 нс
RoHSSee ti.com
  • How to Select Little Logic (Rev. A)
    PDF, 1.1 Мб, Версия: A, Файл опубликован: 26 июл 2016
    TI Little Logic devices are logic-gate devices assembled in a small single- dual- or triple- gate package. Little Logic devices are widely used in portable equipment such as mobile phones MP3 players and notebook computers. Little Logic devices also are used in desktop computers and telecommunications. Little Logic gates are common components for easy PC board routing schematic design and b
  • Advanced High-Speed CMOS (AHC) Logic Family (Rev. C)
    PDF, 102 Кб, Версия: C, Файл опубликован: 2 дек 2002
    The Texas Instruments (TI) advanced high-speed CMOS (AHC) logic family provides a natural migration for high-speed CMOS (HCMOS) users who need more speed for low-power and low-drive applications. Unlike many other advanced logic families AHC does not have the drawbacks that come with higher speed e.g. higher signal noise and power consumption. The AHC logic family consists of gates medium-sca
  • Migration From 3.3-V To 2.5-V Power Supplies For Logic Devices
    PDF, 115 Кб, Файл опубликован: 1 дек 1997
    This application report explores the possibilities for migrating to 3.3-V and 2.5-V power supplies and discusses the implications.Customers are successfully using a wide range of low-voltage 3.3-V logic devices. These devices are within Texas Instruments (TI) advanced low-voltage CMOS (ALVC) crossbar technology (CBT) crossbar technology with integrated diode (CBTD) low-voltage crossbar techn
  • Live Insertion
  • Designing with the SN74LVC1G123 Monostable Multivibrator
    PDF, 158 Кб, Файл опубликован: 14 июл 2015
  • Texas Instruments Little Logic Application Report
    PDF, 359 Кб, Файл опубликован: 1 ноя 2002
    Portable and consumer electronic systems? needs present greater challenges today than ever before. Engineers strive to design smaller faster lower-cost systems to meet the market demand. Consequently the semiconductor industry faces a growing need to increase operating speed minimize power consumption and reduce packaging size. Texas Instruments manufactures a variety of Little Logic semicond
  • Introduction to Logic
  • Semiconductors > Space & High Reliability > Logic Products > Specialty Logic Products > Monostable Multivibrator Products
59629861601QFA, 5962 9861601QFA
На английском языке: Datasheet Texas Instruments 5962-9861601QFA
