Datasheet Texas Instruments TPS78227DDCTG4 — Даташит
СерияTPS782
МодельTPS78227DDCTG4
500 нА, IQ 150 мА, линейный стабилизатор со сверхнизким током покоя и малым падением напряжения 5-SOT-23-THIN -40–125
TPS782 500-nA IQ,150-mA, Ultra-Low Quiescent Current Low-Dropout Linear Regulator datasheet
PDF, 1.1 Мб, Версия: D, Файл опубликован: 5 ноя 2014
Pin5
Package TypeDDC
Industry STD TermSOT-23-THIN
Package QTY250
CarrierSMALL T&R
МаркировкаCVE
Width (мм)1.6
Length (мм)2.9
Thickness (мм).87
Pitch (мм).95
Max Height (мм)1.1
Точность3 %
Fixed Output Options1.8,2.2,2.3,2.5,2.7,2.8,3,3.3,3.6 В
Iout(Max)0.15 A
Iq(Typ)0.0005 мА
Noise86 uVrms
Output Capacitor TypeCeramic
Output OptionsFixed Output
PSRR @ 100KHz13 дБ
Package GroupSOT-23-THIN
Package Size: mm2:W x L5SOT-23-THIN: 8 mm2: 2.8 x 2.9(SOT-23-THIN) PKG
Regulated Outputs1
Special FeaturesEnable,Output Discharge
Thermal Resistance ОёJA66 В°C/W
Vdo(Typ)130 мВ
Vin(Max)5.5 В
Vin(Min)2.2 В
Vout(Max)3.6 В
Vout(Min)1.8 В
  • Evaluation Modules & Boards: TPS78230EVM-445
    TPS78230EVM-445 Evaluation Module
  • Evaluation Modules & Boards: TPS78233EVM-445
    TPS78233EVM-445 Evaluation Module
  • Evaluation Modules & Boards: TPS78227EVM-445
    TPS78227EVM-445 Evaluation Module
  • Evaluation Modules & Boards: TPS78225EVM-445
    Evaluation Module for TPS782xx Low Dropout Linear Regulator
  • 3.6V - 5.5V Input LDO Reference Design for MSP430 (Rev. A)
    PDF, 110 Кб, Версия: A, Файл опубликован: 14 июн 2010
    This reference design is presented to help application designers and others who are trying to use the MSP430 in a system with an input voltage in the range of 3.6 V to 5.5 V and who are also interested in using an easy-to-use low-dropout linear regulator (LDO) for a simple design but may not be as concerned about maintaining the highest possible efficiency or longest battery life.
На английском языке: Datasheet Texas Instruments TPS78227DDCTG4
