Datasheet Texas Instruments LM5115AMTX/NOPB — Даташит
СерияLM5115A
МодельLM5115AMTX/NOPB
75 В, вторичный боковой пост-регулятор/синхронный понижающий контроллер с отслеживанием включения/выключения питания 16-TSSOP от -40 до 125
Secondary Side Post Regulator/DC-DC Converter with Power-up/Power-down Tracking datasheet
PDF, 950 Кб, Версия: B, Файл опубликован: 26 мар 2013
Pin1616
Package TypePWPW
Industry STD TermTSSOPTSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY25002500
CarrierLARGE T&RLARGE T&R
МаркировкаLM5115AMT
Width (мм)4.44.4
Length (мм)55
Thickness (мм)11
Pitch (мм).65.65
Max Height (мм)1.21.2
Control MethodValleyCurrent
Duty Cycle(Max)85 %
Frequency(Max)1000 kHz
Frequency(Min)50 kHz
Gate Drive(Typ)2.5 A
Package GroupTSSOP
Special FeaturesSoft Start
TopologySynchronous secondary-side post-regulator
UVLO Thresholds On/Off4.25/4.0 В
Vin(Max)75 В
Vin(Min)4.5 В
  • Evaluation Modules & Boards: LM5115AEVAL
    Secondary Side Post Regulator DC-DC Converter with Power-up Power-down Tracking
  • Minimizing FET Losses For a High Input Rail Buck Converter (Rev. A)
    PDF, 168 Кб, Версия: A, Файл опубликован: 23 апр 2013
    Engineers often face the challenge of choosing the input voltage rail that works best for the DC-DCconverter at the point-of-load (POL). High voltage rails, above 12 V, usually demand intermediateregulation stages that reduce overall efficiency and add to cost. However, the new generation of regulatorand controller ICs afford POL regulation from these high input rails directly. Typically the
Серия: LM5115A (2)
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
На английском языке: Datasheet Texas Instruments LM5115AMTX/NOPB
