Datasheet Texas Instruments TAS5010PFBR — Даташит
СерияTAS5010
МодельTAS5010PFBR
Цифровой аудиопроцессор ШИМ 48-TQFP от 0 до 70
Статус продуктаСкоро будет снят с производства (Производитель объявил о скором прекращении производства прибора)
Pin48
Package TypePFB
Industry STD TermTQFP
JEDEC CodeS-PQFP-G
Package QTY1000
МаркировкаTAS5010
Width (мм)7
Length (мм)7
Thickness (мм)1
Pitch (мм).5
Max Height (мм)1.2
Approx. Price (US$)4.02 | 1ku
Digital Supply (up to 5 V)(Max)(V)3.6
Digital Supply (up to 5 V)(Min)(V)3
Dynamic Range(dB)96
Fs(Min)(kHz)44.1
Half Power THD + N @ 1 kHz (%)(kHz)Less Than 0.08
Operating Temperature Range(C)-40 to 85
0 to 70
Package GroupTQFP
Package Size(mm2=WxL)48TQFP: 81 mm2: 9 x 9
Speaker ChannelsStereo
  • System Design Considerations for True Digital Audio Power Amplifiers (Rev. A)
    PDF, 675 Кб, Версия: A, Файл опубликован: 12 ноя 2001
    This report describes the conversion of pulse-code-modulated (PCM) to pulse-width-modulated (PWM) signals using Texas Instruments TDAA modulation devices (TAS50xx) and signal amplification using Texas Instruments family of H-bridge output stages (TAS51xx). It includes a detailed discussion of power supply voltage requirements, output circuit filters, and thermal dissipation. An example stereo appl
  • Power Supply Recommendations for DVD Receivers
    PDF, 153 Кб, Файл опубликован: 4 май 2005
    Selecting the optimal power supply for a non feed back digital amplifier can bechallenging. Music is dynamic, so the power consumption is changing dramatically,from almost zero to maximum within a few ms.Designing the power supply so powerful that it can deliver the total amplifier outputpower continuously is too costly and usually unnecessary.Designing the power supply too small gives p
  • PSRR for Purepath Digital Audio Amplifiers
    PDF, 159 Кб, Файл опубликован: 15 апр 2005
Серия: TAS5010 (4)
  • Semiconductors > Audio > High-Power Audio Amplifiers (>50W) > PWM Input Class-D
На английском языке: Datasheet Texas Instruments TAS5010PFBR
